Rebuild Top End - Page 2 - Honda ATV Forum
post #11 of 15 (permalink) Old 06-06-2011, 02:40 PM
Liked: 54 times
It was running good before you rebuilt it you mean,or it was running good earlier before you messed with the timing???It will not run if the cam is off timing at all,if you're 180 degrees off it might backfire through the carb but won't run...You have to find the correct TDC mark as at the other time it is at tdc of a stroke will it be out 180 degrees...
Deeperinthabush is offline
post #12 of 15 (permalink) Old 06-06-2011, 02:42 PM
Liked: 24 times
On the 250EX, you don't have to mess with the timing to rebuild the top end. The 250EX is a push rod engine, with the cam in the bottom of the engine.
post #13 of 15 (permalink) Old 06-06-2011, 02:53 PM Thread Starter
kevinsonnier24's Avatar
I'm trying to set the valves
kevinsonnier24 is offline
post #14 of 15 (permalink) Old 06-06-2011, 02:56 PM
Liked: 24 times
Are you saying that it was running good and then you tried to adjust the valves and now it won't run? If so, did you set the valves with the piston on TDC on the compression stroke and not TDC on the exhaust stroke?
post #15 of 15 (permalink) Old 06-06-2011, 03:00 PM Thread Starter
I rebuilt the top end while putting back together I tried setting the valve clearence because I had the valve seals changed while apart
