recon pushrods - Honda ATV Forum
Old 04-07-2011, 08:59 PM   #1 (permalink)
burmar's Avatar
Member #9598
View burmar's Photo Gallery(0)
recon pushrods
how do you line up the push rods on a 250
burmar is offline   Reply With Quote
Old 04-07-2011, 09:06 PM   #2 (permalink)
Welcome to the forums. You just stick the push rods down through the hole in the head and cylinder into the cam followers. Then, just guide the ends of the push rods into the "cups" on the rocker arms as you bolt on the rocker arms. It will be a little easier if you put the piston on TDC on the compression stroke, so the cam lobes are down, but you don't have to.
Old 04-07-2011, 10:09 PM   #3 (permalink)
burmar's Avatar
Member #9598
Thanks for the tip.I hope it work, gave up on it today i am a body man not a mechanic.
Old 04-08-2011, 06:17 AM   #4 (permalink)
Member #417
Liked: 304 times
Old 04-08-2011, 10:21 PM   #5 (permalink)
burmar's Avatar
Member #9598
Still could not line the push rods up do I need to take the rocker arms loose from the box to line up the push rods
Old 04-08-2011, 10:55 PM   #6 (permalink)
No, you don't have to take the rocker arms loose from the cover. Put the piston at TDC on the compression stroke by aligning the "T" mark. Make sure it's on the compression stroke and not the exhaust stroke. On the compression stroke, both push rods will be at their lowest point. If they're not, turn the flywheel one full revolution and stop on the "T" mark again. When you put the two push rods down through the head, make sure they're centered and parallel to each other. Then put the head cover on. If you need to, take the round valve adjusting covers off and stick your fingers through the holes as you put the cover on and you can push on the rocker arms to raise them up to help them align with the tops of the push rods.
The earlier models were a little easier to line up because the rocker arms weren't built into the cover and you could see how to align them up better. You must have a 2002 or up model if the rocker arms are incorporated into the cover.
Old 04-08-2011, 11:22 PM   #7 (permalink)
burmar's Avatar
Member #9598
Thanks helmut this thing is driving me crazy and a 12 year old ready to ride the wheels off of it he cuts grass and bought it as a basket case got to ride for about a month then it started breaking. It is a 2002 got it for 300.00
Old 04-09-2011, 01:14 PM   #8 (permalink)
You're welcome and good luck!!
Old 04-09-2011, 07:47 PM   #9 (permalink)
Liked: 1522 times
body man eh ?..damn..where were you when i needed a motor cycle gas tank repaired ??..lol.
2002 honda recon 250 es pushrod
250 recon push rod direction
250ex push rods
burmarphoto
does honda have push rods
honda 250ex pushrods
honda recon 250 pushrods
honda recon pushrods
how do you replace push rods on a 1998 honda 250 recon
recon 250 push rod
recon 250 pushrods
replace push rods. in honda 250ex
