Old 03-20-2011, 08:10 AM   #1 (permalink)
Jason Murphy's Avatar
Member #9189
View Jason Murphy's Photo Gallery(0)
2003 trx250ex wont run
It has spark and is getting fuel but will not start. It wil pop a couple of times and thats all. It got stuck in the snow and hasnt run since . I have drained gas and put new in. put new plug in.changed air filter. any ideas
Jason Murphy is offline   Reply With Quote
Old 03-20-2011, 08:18 AM   #2 (permalink)
Redracer's Avatar
Member #618
View Redracer's Photo Gallery(0)
How does the air filter/air box look? Did any mice make the airbox a home?
Dynamic Graphics, Inc.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline   Reply With Quote
Old 03-21-2011, 07:21 PM   #3 (permalink)
Member #9189
I changed filter still wont run
Old 03-21-2011, 07:51 PM   #4 (permalink)
bobs330's Avatar
Member #8144
man you mention mice, i had a thread about rats eating a tube and it wouldnt run, it was cold out kinda like what your saying here.
Old 03-21-2011, 09:03 PM   #5 (permalink)
my5sons's Avatar
Member #7182
I have a 2006, and mine did the same thing. Ended up needing a carb clean. Once I got it cleaned, I ended up frying the cdi. What happens if you pour a small capful of fuel down the spark plug hole and then try and start it? Will it run for a few seconds?
The only thing that throws me off is that you say that it got stuck in the snow and hasn't run since. ????? Carb isn't going to dirty itself in the snow, but if you let it sit for 2-3 months or longer after that, you will need to clean it anyway.
How are you sure it's getting spark?
> Click Here for Answers to Frequently Asked Questions < - updated February 29, 2012
>> Click Here to Download your Service/Repair Manual << - updated Feb 13, 2012
1996 TRX300FW - ITP Mudlites Warn XT25
2001 Suzuki LT A50
2003 TRX300EX - my PROJECT
2006 TRX250EX - Maxxis Razrs
2008 TRX450ER - All Stock 130 Main, 55 leak jet
Old 03-21-2011, 10:50 PM   #6 (permalink)
first..spray a short burst of starting fluid in the carb...does it fire up and run ?..if so..then you got carb issues...if it don't fire up and run for a few sec's..then you got compression issues..either from jumped timming..or bad rings.
'89 trx350D foreman 4x4...'85 vf700c magna, '99 XLT 1200 limited jet ski, '87 super magna
Old 03-22-2011, 12:42 PM   #7 (permalink)
my5sons's Avatar
Member #7182
pros and cons to starting fluid. I have used it, but just don't get happy with that$ 1.50 can! Spray a short burst like shadetree says. If it fires up for a short time, DO NOT repeat the process. You have already found the problem. Continuing to run it with repeated bursts is NOT recommended.
You can spray some on the filter if you like. I used to use starting fluid, but no longer want the risk. Others use it religiously. Your choice.
2001 Suzuki LT A50
Old 03-22-2011, 02:09 PM   #8 (permalink)
If you don't feel comfortable using starting fluid, just pour some gasoline in a spray bottle and use it.
Old 03-23-2011, 05:02 PM   #9 (permalink)
Member #9189
I tried starting fluid and still nothing.Pulled plug and put it by metal and could see it spark.It has a aftermarket pipe . Checked it and it has no gasket on the head. Burnt valves? Thanks For all the help.
Old 03-24-2011, 06:08 PM   #10 (permalink)
Reconman31's Avatar
Member #8899
View Reconman31's Photo Gallery(0)
check the valve clearances. Sounds like what my Recon was doing and I was told to check the valves and the intake valve was tight so it wouldnt start
2003 honda recon- itp mudlights
2008 kawasaki kx250f- too much stuff to list, too many broken bones going up for sale soon
Reconman31 is offline   Reply With Quote
03 trx 250 wont fire
2001 honda recon 250 wont start
2003 honda trx250ex owners manual
2003 honda trx250ex specs
2003 trx250ex
2003 trx250ex service manual
honda 250ex compression
honda 250ex not getting any fuel
honda recon 250 torque specs
honda trx250ex wont start
how to find out why my trx250ex wont start.
trx250ex no start
