2000 Cooling Fan on Rancher 350 - Honda ATV Forum
Old 03-13-2011, 09:04 AM   #1 (permalink)
tedhunter's Avatar
Member #7581
View tedhunter's Photo Gallery(0)
While pulling out several loads of firewood over the past weeked, i noticed that the cooling fan wasn't coming on.
I checked the fan and have power to it but the fan is bad. After calling the local ATV supplier, I got a 270ish price. OUCH. It is a 2000 model - sorry, i hit -01 in the title.
Is the fan on the 4x4 and the 2x4 the same and if so, what years are in the range to interchange? I don't have a parts listing for the 4x4 but I have noticed that some of the bracketing is different.
THanks for any help,
Ted
2000 Rancher 350 ES in rebuilding mode!!!
tedhunter is offline   Reply With Quote
Old 03-13-2011, 09:10 AM   #2 (permalink)
Redracer's Avatar
Member #618
View Redracer's Photo Gallery(0)
Liked: 5 times
I edited the title of your thread...
One thing you can do is check the OEM parts list for both machines. Sites like Motorcycle Parts, Motorcycle Accessories can provide a list of part numbers for you. If they both have the same part number, you nare golden.
Dynamic Graphics, Inc.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline   Reply With Quote
Old 03-13-2011, 09:22 AM   #3 (permalink)
tedhunter's Avatar
Member #7581
RR - Thanks for fixing the title! I'll check the parts link and see if i can track it backwards.
Thanks again,
Ted
Old 03-13-2011, 09:28 AM   #4 (permalink)
tedhunter's Avatar
Member #7581
RR - that is an exceptional site! Another bookmark added.
Ted
Old 03-13-2011, 03:40 PM   #5 (permalink)
Did you make sure the fan motor is actually bad, because on that model, the ECU uses the ground to turn the fan on and off. The power wire runs straight to the fan motor, but it won't work until the ECU grounds the circuit. You could have a bad fan control unit or a bad oil temp sensor.
Also, I think the fans are all the same on the 2000-2002 Rancher. Note that the 2wd, foot shift model doesn't have a fan, but all the other models do.
Old 03-24-2011, 09:04 PM   #6 (permalink)
tedhunter's Avatar
Member #7581
Good evening Helmut, I was out of town on a jobsite for a couple of weeks and just now am getting back to check everything out.
You were right - It wasn't the fan. I had already changed the fuse and figured it blew when the fan died and fed back. Ok - i checked the power from the battery to the fan again and it was shorted out somewhere (i got intermitten voltage when i moved the harness) so I hooked a line from the battery to an inline (marine rated) fuse to the fan and then grounded the circuit and BUZZ - we got air flow. I'll check the oil temp sensor tomorrow and see what it shows. Basically - when the temp rises, closes the 'stat and then grounds the fan to run. That therefore means that the "thermostat" is in the ECU and not easily replaced.
Where's that darn manual!
Also, any reason behind the foot shift model not having a fan?
Thanks Helmut -
ted
Old 03-24-2011, 09:20 PM   #7 (permalink)
You're welcome and there's a link to the 350 Rancher service manual in the manuals/schematics section of the forum.
Old 03-24-2011, 09:24 PM   #8 (permalink)
bobs330's Avatar
Member #8144
why would the 350TM not have a fan???
Old 03-24-2011, 09:29 PM   #9 (permalink)
I don't really know why the 2wd, foot shift models don't have a fan, I just know that they don't. They might figure the 2wd doesn't need a fan, but added it to the 2wd, electric shift models because of the ESP. I don't know, just a guess.
Old 03-24-2011, 09:29 PM   #10 (permalink)
tedhunter's Avatar
Member #7581
GOt it open now but will have to wait until tomorrow. WIfe just turned the breaker off that powers the lights out here in the garage. I gotta change the line to a new breaker to throw her off.
2001 honda rancher 350 fan not working
2001 honda rancher 350 trouble cooling fan
2001 honda rancher cooling fan wont come on
2002 honda rancher 350 fan not working
2002 honda rancher cooling fan not working
2002 rancher es 350 thermostat
atv honda atv 350 ranchers 2000 models come out with fans
honda rancher 2000 fan motor controll
howto check fan 2000 honda rancher
problems with a cooling fan on a 2000 honda rancher
were is the temperature sensor location that makes the oil cooler fan come on on 2002 honda rancher 350 es
where is fan sensor on honda ranchrr
