400ex engine re-assembly - Honda ATV Forum
post #1 of 10 (permalink) Old 03-10-2011, 01:17 PM Thread Starter
SlammedRanger's Avatar
Liked: 188 times
Question 400ex engine re-assembly
I ended up having to pull the head off my 400ex and was wondering what the torque specs are for the head bolts, and what order do you torque them in. I don't want to buy the clymers if I don't have to and I have built quite a few different motors. Thanks!
07 416ex
Wiseco 87mm piston(fly cut for clearance)
Stg 2 magnum cam
Kibble white +1 valves (high rev springs+titanium retainers)
Crf450 t-chain
Cometic gaskets
Gt thunder hd studs
EBC DRC Clutch
PRM skid
Hmf full pipe
UNI filter + ehs powerlid
45 pilot, 1 3/4 turns, middle clip, 190 main
razr XC tires
Team Alba (bumper,nerfs,beadlocks,+2 lt arms)
Mod quad dash
Acerbies handguards
Msr ez pull lever
Oury grips
Fasst Flexx bars
TCS triple rate front shocks
PEP rear shock
SlammedRanger is online now
post #2 of 10 (permalink) Old 03-10-2011, 02:07 PM
Liked: 204 times
im unsure as to what the specs are but a quick google search usually helps a ton. or call a local honda shop they will tell ya
Manny is offline
post #3 of 10 (permalink) Old 03-10-2011, 02:26 PM
Head bolts torque at 33 ft-lbs. and are tightened in a crisscross pattern in 2 or 3 steps.
post #4 of 10 (permalink) Old 03-10-2011, 06:52 PM Thread Starter
Liked: 188 times
Right on helmut thank you very much! And the google thing I would go there but is the info trustworthy enough for a very precise and needed answer. I know where to go and who I can trust on here. Helmut always has the answers lol. But thanks fellas either way!
07 416ex
Stg 2 magnum cam
Crf450 t-chain
Cometic gaskets
Gt thunder hd studs
EBC DRC Clutch
PRM skid
Hmf full pipe
razr XC tires
Mod quad dash
Acerbies handguards
Msr ez pull lever
Oury grips
Fasst Flexx bars
PEP rear shock
post #5 of 10 (permalink) Old 03-10-2011, 08:32 PM
You're welcome. Yeah, I got the info from the service manual, so it should be accurate.
post #6 of 10 (permalink) Old 03-10-2011, 08:37 PM Thread Starter
Liked: 188 times
I wouldn't doubt any answer from u helmut. Google is a different story lol. Just my opinion of course. And heck I trust the fsm more than a clymers even. Thanks again!
07 416ex
Stg 2 magnum cam
Crf450 t-chain
Cometic gaskets
Gt thunder hd studs
EBC DRC Clutch
PRM skid
Hmf full pipe
razr XC tires
Mod quad dash
Acerbies handguards
Msr ez pull lever
Oury grips
Fasst Flexx bars
PEP rear shock
post #7 of 10 (permalink) Old 03-10-2011, 08:43 PM
You're welcome.
post #8 of 10 (permalink) Old 03-10-2011, 08:45 PM
Liked: 316 times
When you do torque them set your wrench to half the total value and work your way to the max torque, you will get a more even seal.
TRX2fiveO is offline
post #9 of 10 (permalink) Old 03-10-2011, 08:57 PM Thread Starter
Liked: 188 times
Awesome good info thanks! I ordered a namura topend gasket kit so its gunna have a new head gasket. do you have to put anything on the head gasket? It looks like there was some sort of sealer on it when I pulled it off. And i am certain I'm the first one pulling this motor apart so it wasn't something someone did.
07 416ex
Stg 2 magnum cam
Crf450 t-chain
Cometic gaskets
Gt thunder hd studs
EBC DRC Clutch
PRM skid
Hmf full pipe
razr XC tires
Mod quad dash
Acerbies handguards
Msr ez pull lever
Oury grips
Fasst Flexx bars
PEP rear shock
post #10 of 10 (permalink) Old 03-10-2011, 09:06 PM
No, you don't need to put anything on the head gasket.
