09 450er starting problems - Honda ATV Forum
post #1 of 18 (permalink) Old 03-07-2011, 04:56 PM Thread Starter
savannahrider's Avatar
hey guys just trying to figure out what is wrong with my quad. have an 09 trx 450er and just bought a new battery thinkin it was it. fired up fine and got out to the race and lap 2 into the woods the engine killed. tried starting it and all it would do was click. it would try and turn over but over time i just drained the battery. the neutral light shows up green but it wont turn over. im thinking maybe the start solenoid? any help i would greatly appreciate it.
savannahrider is offline
post #2 of 18 (permalink) Old 03-07-2011, 05:17 PM
bobs330's Avatar
did the engine just die on its own or just from stalling somehow?
bobs330 is offline
post #3 of 18 (permalink) Old 03-07-2011, 05:24 PM Thread Starter
i was pretty tired but i dont think i stalled it. i have a rekluse clutch so i didnt really stall it i dont think. this did this to me while i was in wv a few months ago so i thought it was the battery. guess i was wrong.. the clicking is on the solenoid and battery
post #4 of 18 (permalink) Old 03-07-2011, 05:28 PM
bobs330's Avatar
hmm. thats over my head.
bobs330 is offline
post #5 of 18 (permalink) Old 03-07-2011, 05:49 PM
Redracer's Avatar
Liked: 5 times
I'm thinkng you are correct
Dynamic Graphics, Inc.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline
post #6 of 18 (permalink) Old 03-07-2011, 06:04 PM
my5sons's Avatar
I wouldn't guess at anything. If you don't know how to test the battery, Take your battery to an auto parts store and have them test it. If it comes back good battery, just needed charged, then your charging system isn't working. I would never buy a battery" thinking" it was my problem. You're just throwing money away.
2001 Suzuki LT A50
2003 TRX300EX
2006 TRX250EX - Maxxis Razrs
my5sons is offline
post #7 of 18 (permalink) Old 03-07-2011, 06:37 PM
Liked: 1733 times
agreed ^^^^^^^..have the battery tested..if it's gone..and you run a new battery...and it does it again..i would say your stator is bad..not re-charging your battery...it's not a good idea to run any bike either with a dead battery..or no battery at all...as this puts your stator..and reg/rec into over drive..thus..killing it in the long run.
post #8 of 18 (permalink) Old 03-07-2011, 07:24 PM Thread Starter
it was a quick fix to race. always wait until the last minute to do things. where is the stator located. do you not think its the solenoid?
post #9 of 18 (permalink) Old 03-07-2011, 07:29 PM
my5sons's Avatar
You should definitely get a service manual if you are doing your own work.
As stated, get the battery tested or you're just guessing. If you don't get enough power (read cranking amps/voltage) to the solenoid, it will click as you describe.
Get the battery tested. If it's a bad battery, then you can move on in troubleshooting. Without a good battery, you will be chasing your tail. Sometimes you get lucky just replacing parts, other times, you can lose your wallet! Don't guess, and start with a clean known good battery and check back and tell us what you found.
2001 Suzuki LT A50
2003 TRX300EX
my5sons is offline
post #10 of 18 (permalink) Old 03-07-2011, 07:34 PM
Liked: 24 times
I agree, get a good battery and make sure all the battery cable connections are clean and tight. Then, if it still won't start, jump the two posts on the solenoid and see if it will start. If it starts then, your solenoid is likely bad. Note that a bad solenoid won't cause the engine to stall, but it can keep it from starting back.
