Last summer I picked up 2 1985 trx250 and a 1987 trx250. I'm trying to at least make 2 good running wheelers. Want to take one and make it little sporty lower it little and do some custom lights and bumpers. And another one I'd like to make a mudder, mount winch and custom bumpers and lights. I know it's only 2 wheel drive but with good tires and ground clearance you can go through a lot.
Any tips or ideas or parts sites would be greatly appreciated. Only have one set of plastics. so I'd like to try to fit just about any random plastics on but I'll see what I can come up with
So far I got one on the 1985s motor takin apart had a stuck valve was able to get it unstuck. Got to see if I can get away with reusing the valve and guide. Going to hone the cylinder and measure it this weekend and get a parts list make up and start ordering.
for bumpers and such ?, unless your really good at fabbing these ?, your not going to find any one that makes them , not that I know of anyway ?. these are utility atvs, they were never meant to be sport atvs ?, sooo..your only choice is to make all your own parts. take the winch mounting plate for starters ?, they never made a mounting plate for that atv model ?, soooo, you must fab your own. as for making one into a 4wd type ?, well..yes..it may look good to you ?, but !!. the problem your going to run into, is the j-shock mounts only allow you so much lift ?, if you go to far up ?, your tie rods are going to drag the frame. these are just a few things off the top of my head from memory . oh, and you can't go to large of tires !, because the fender flares will bottom out on them !.
..... a plastic 55 gallon drum , jig saw and some imagination can make a set of fenders , I have seen it done and it is not half bad ------------- would you happen to be close to Louisiana , I have a lot of parts for those bikes that I would part with , but don't ship
Was planning on some fab work, I'm pretty good with a grinder and welder. It was just thoughts and ideas I was tossing out there. Your guys ideas are appreciated to the fullest never thought of using a drum. On the 87 someone built some plywood rear fenders. They look pretty good but get in the way of the kick start I'll take pic when I get out to the garage. No flys I live up in northern wi. It's hard to find parts round here been watching Craigslist and Facebook like crazy to see if I can find anything
Here's that 87' with the plywood fenders. On my way to pick up some parts for my grizzly 660 when I get home I'm going to start cleaning and measuring for piston
Started cleaning up all the parts today got my cylinder honed and measured up. Think all I am gonna have to do is new piston and gaskets everything is looks pretty good. I don't think that piston is useable at all
.... if it were me , I would send the jug to G+H and have it freshened up , for $220 you would have a new piston fitted to a fresh bore and all the gaskets to do the job
heavy , I think G+H charges $155 for the head job , I do the heads myself , it is not hard , you would need a spring compressor and a valve lapping stick with grinding compound , unless you have a bent valve stem or valve guide problem , which you said you had a valve stick on you so you might do better sending it off -------- since you have it that far down , I would suggest a new timing chain and cam sprocket , don't skimp on the sprocket , I skimped and it came back to bite me
Was a busy week at work finally got to do little work on the wheeler. Got all the engine parts cleaned up and all the little chunks of piston out and it's ready to go back together. Also started working on the frame/rear axle got the brakes broke free but looks like I need new bearings and new brake cable now so gonna order them up tonight along with gasket kit, piston, and see bout sending my head off to g&h and look in to timing chain and sprocket
Related Threads
618.3K posts
80K members
Since 2008
