Cam chain timing (400ex) - Honda ATV Forum
Old 01-16-2013, 09:10 PM   #1 (permalink)
Dcherill's Avatar
Member #27947
View Dcherill's Photo Gallery(0)
I picked up a 2005 400ex for cheap because it didn't run, no compression. Ended up being a cracked valve seat. Sent the jug and head out, put it back together with a new weisco 11:1 piston and a white brothers WB1498 cam off ebay. Also rebuilt the carb. During the rebuild, the cam chain was very slack and rattled around in the crankcase freely (more on this later). i put the whole thing back together, and noticed during the cam install that the timing lines were just a little off of square from the top of the head. Didn't think too much of it, put it all back together, and now it wont run...
I am running a full air box with snorkel, k&n, and a new FMF powercore4. Jetted at 165/42, 3 turns out. No adjustable needle
If i hit the accelerator pump before cranking a couple times, i can get it to sputter, and if i hit the throttle just right, i can get it to run, just not idle, it immediately dies, but if i hold it, it will stay running high, so it is drawing a vacuum properly from what i can tell
So after reading and reading, i decided a stage1 hotcam is going to better suit my terrain (tighter woods), so i have the cam torn out, and was wondering if the cam chain can skip a tooth on the crank to affect timing? Or did i just adjust my valves wrong?
Open to any ideas, i can grab a shot of the cam timing mark if that could be useful
Halp!
Dcherill is offline   Reply With Quote
Old 01-17-2013, 05:30 AM   #2 (permalink)
Member #417
Liked: 286 times
Welcome to the forums. . . .YOu did install the cam lobes down correct??what I normally do it set the dash mark closest to the timing tensioner or back of the engine a little higher than the head surface maybe 1/16-1/8th so when you snap the tensioner back to it's working position it will pull the chain tight and the cam right where it needs to be. check your cam sheet for the valve lash specs and set it to them. What are you going to do with the White brothers cam? might have a buyer if the price is right???
Old 01-17-2013, 02:12 PM   #3 (permalink)
Dcherill's Avatar
Member #27947
yes, lobes down. so you don't think 1 or 2mm difference on the timing tics is enough to throw it off? I'll re-do the valves for the new cap specs. i was thinking the cam lines would have been perfectly parallel to the top of the motor
cam is for sale, let me know what you think the right price is...
Old 01-17-2013, 02:44 PM   #4 (permalink)
Member #417
Liked: 286 times
Check your valve clearance again. They may be to tight. .
Old 01-17-2013, 02:54 PM   #5 (permalink)
Liked: 52 times
If the chain has any slack with the tensioner installed,replace the chain now,then set the cam up with the new chains slack on the tensioner side,install the tensioner,and check the alignment marks,if off a tooth,remove the tensioner,and back the cam up a tooth,reinstall tensioner...then rotate the engine by hand ,and check the timing marks again,if the lobes are down,the t marks aligned,and the cam marks are dead on then it is right ...
Old 01-17-2013, 03:56 PM   #6 (permalink)
rich250rracer's Avatar
Member #13858
View rich250rracer's Photo Gallery(0)
Liked: 14 times
If you need to replace the chain, be sure to use a CRF450 timing chain, part# 14401-MEB-671. It is a much stronger chain and about half the price of a 400EX chain.
2014 CRA Senior II and Buckeye Series champ
2012 CRA Senior II champ
2011 CRA Senior II and Buckeye series Harescramble Champion
2009 CRA Senior II and Buckeye series champ.
2007 CRA Senior II, and Buckeye series Harescramble Champ.
2007 TRX450R
2005 TRX450R
2004 TRX450R
2003 Lonestar 250R
1999 CR500
1999 CR250
1996 CR250
1986 ATC250R
1975 MR50
1999 Banshee
rich250rracer is offline   Reply With Quote
Old 01-17-2013, 09:20 PM   #7 (permalink)
Dcherill's Avatar
Member #27947
Ok! Sage 1 cam in and timed the same ever so slightly off as the wb cam. Pulled the plug during the timing portion to relieve compression, and noticed that the gap was extremely tight. New plug, gapped properly. Adjusted the valves and originally made the idiot mistake of .15" instead of .15mm. Threw the whole thing together, and it sputtered a bit more than i was used to and eventually got it running, then idling! It is in the 30's tonight so i bet she was a little cold, hence the hesitation. Didn't let it idle too long as i want to break in the cam and engine properly, so i need some good variation etc. threw the skins on it, ready for tomorrow!
TL;DR: plug gap and the difference between inches and mm for valve adjustment
And that WB cam is still up for grabs if you know anyone. Ill even throw in the hogged out sprocket (for advanced timing) that i got with it
Thanks everyone!
Old 01-17-2013, 10:30 PM   #8 (permalink)
Liked: 52 times
You can post an ad for the cam in the for sale section on the main page(click atv forum up top),then scroll down to the bottom..
Old 01-18-2013, 05:08 AM   #9 (permalink)
Member #417
Liked: 286 times
Glad you got it going
2003 400ex specstimingcam
2004 honda 400ex timing marks
2007 honda 400ex timing
400ex cam position
honda 400ex cam timing
how to time a 400ex
how to time a 400ex honda
how to time a honda 400ex
how to time a trx400ex
timing specsfor 2003 hontrx 400ex
trx400ex timing
youtube honda 400ex cam timing
