400ex exhaust and jets - Honda ATV Forum
Old 10-17-2012, 04:33 PM   #1 (permalink)
intillect's Avatar
Member #23425
View intillect's Photo Gallery(0)
Hey i have a 2004 honda 400ex and i am getting a fmf power core 4 slip on for it. Do i need to rejet my carb and if so what size jets would be best. Thanks
intillect is offline   Reply With Quote
Old 10-17-2012, 07:15 PM   #2 (permalink)
slincolnn's Avatar
Member #14099
Yes you need to rejet your carb around a 165-170 should be a good place to start but you could go larger depending on other things that you have on your bike.
07 Foreman 500
04 250ex
06 yamaha Wolverine 450
03 recon
Old 10-17-2012, 07:18 PM   #3 (permalink)
intillect's Avatar
Member #23425
the four wheeler is completely stock and to my understanding there are 2 or 3 jets not just one. Do the other need to be adjusted or replaced with bigger ones. Thanks for the reply.
Old 10-17-2012, 07:26 PM   #4 (permalink)
slincolnn's Avatar
Member #14099
Well most people put a larger pilot jet in to make the 400 not so cold blooded.You can upgrade to a 42 pilot as far as a needle adjustment you won't have to adjust it at all.
07 Foreman 500
04 250ex
03 recon
Old 10-17-2012, 07:32 PM   #5 (permalink)
intillect's Avatar
Member #23425
so if i put a 42 pilot jet in and a 165 in it what will the performance boost be. i will also have the fmf slip on
Old 10-17-2012, 07:36 PM   #6 (permalink)
slincolnn's Avatar
Member #14099
I'm not sure I've never road a stock 400ex.You may need a larger main jet it just depends on how your plug reads but a 165 would be a starting place.
07 Foreman 500
04 250ex
03 recon
Old 10-17-2012, 07:38 PM   #7 (permalink)
intillect's Avatar
Member #23425
alright thanks that is a huge help so would you say to put in the 165 with the slip on and ride it for a bit then check the plug and adjust from there? what adjustment should be made if its too rich or too lean?
Old 10-17-2012, 07:41 PM   #8 (permalink)
slincolnn's Avatar
Member #14099
If it's too rich then you need a smaller main and if it's too lean you need a larger main.This time of year you will probably want to be on the rich side because of the weather getting colder.Then in the summer you can pull your air box lid and probably be dialed in for the hot summer weather.
07 Foreman 500
04 250ex
03 recon
Old 10-17-2012, 07:44 PM   #9 (permalink)
intillect's Avatar
Member #23425
alright and the main jet is the 40 or 42 ?
Old 10-17-2012, 07:49 PM   #10 (permalink)
slincolnn's Avatar
Member #14099
No that is the pilot jet which is for idle.Altitude makes a difference also so if you are at higher elevations then you will have to adjust for that too.
07 Foreman 500
04 250ex
03 recon
2004 honda 400ex rejet exhaust
400 ex jets
400ex exhaust
400ex what size jets
best jets for 400ex
bigger or smaller jet for exhaus atv
cobra pipe 400ex jet size?
jets 400ex
lexx mxe 400ex jet size
lexx mxe exhaust 400ex
what size jet 400 ex fmf powercore
what size jets for a 400ex
