Gear reduction on 2012 foreman 500 - Page 2 - Honda ATV Forum
Old 09-29-2012, 10:25 PM   #11 (permalink)
a_tack's Avatar
Member #23685
View a_tack's Photo Gallery(0)
If it gets real thick. Then I just gear down and putt out.
Done
a_tack is offline   Reply With Quote
Old 09-29-2012, 10:30 PM   #12 (permalink)
elovell's Avatar
Member #18649
View elovell's Photo Gallery(0)
Rich I'm just trying to stop the bogged down feeling I get when in the mud. I don't sling mud 5 ft now. I know I should have more power then I do so I'm just trying to add it somehow. exhaust, EFI programmer or GR.
2012 foreman 500
SLC 2 1/2 inch lift
27-10-12 mudlite xl
27-12-12 mudlite xl
STI HD3 wheels
Spider SLT grips
elovell is offline   Reply With Quote
Old 09-29-2012, 10:43 PM   #13 (permalink)
4man5oo's Avatar
Member #21398
View 4man5oo's Photo Gallery(0)
elovell, i know what you mean my exes are heavy and when i bail off in a hole in 2nd i have to shift down to first cause it bogs down so bad but i can still stop in the thick stuff and stab the gas and have enough low end grunt and spin the tires enough to get out. with that said yes its doggy but you have to remember its only a 500, you traded hp for reliability when you bought a honda! my next mod will be a GR but thats cause i wanna be able to spin 28s or 29.5 in the near future
2012 Foreman
Warn RT 2500 winch
26in Executioners
12in ITP 212
Custom audio tube
4man5oo is offline   Reply With Quote
Old 09-29-2012, 10:51 PM   #14 (permalink)
elovell's Avatar
Member #18649
4man500 what % GR will you go with?
2012 foreman 500
SLC 2 1/2 inch lift
27-10-12 mudlite xl
27-12-12 mudlite xl
STI HD3 wheels
Spider SLT grips
Old 09-29-2012, 11:11 PM   #15 (permalink)
4man5oo's Avatar
Member #21398
well HL says theres is a 21% but i have heard its only a true 15% and james that makes his own is a cheeper replica of HLs GR i would think is the same % but that is the only ones i have found
2012 Foreman
Warn RT 2500 winch
26in Executioners
12in ITP 212
Custom audio tube
Old 09-29-2012, 11:55 PM   #16 (permalink)
elovell's Avatar
Member #18649
who is James and how do I get a hold of this James fella?
2012 foreman 500
SLC 2 1/2 inch lift
27-10-12 mudlite xl
27-12-12 mudlite xl
STI HD3 wheels
Spider SLT grips
Old 09-30-2012, 12:01 AM   #17 (permalink)
SSpeckerwood's Avatar
Member #14111
View SSpeckerwood's Photo Gallery(0)
Pm me. I'll get you his number.
2012 FOREMAN 500FM
26" SWAMPLITES
KFI 3000LBS WINCH W/
AMSTEEL BLUE SYN CABLE.
SSPECKERWOOD 3RD HEADLIGHT SWITCH
QUADBOSS DUO REAR SEAT
THUMB & GRIP HEATERS
HONDA A-ARM GUARDS
SSpeckerwood's YouTube Channel
SSpeckerwood's Photostream
SSpeckerwood is offline   Reply With Quote
Old 09-30-2012, 12:41 AM   #18 (permalink)
Liked: 53 times
You can add a clutch kit for around 60bux that will get the rpms up higher into the power before the clutch comes on which helps quite a bit in mud..
Old 09-30-2012, 12:54 AM   #19 (permalink)
elovell's Avatar
Member #18649
Deeper, you think I should try a clutch kit before getting a GR then? How hard is that to install and where should I look to buy the clutch kit?
2012 foreman 500
SLC 2 1/2 inch lift
27-10-12 mudlite xl
27-12-12 mudlite xl
STI HD3 wheels
Spider SLT grips
Old 09-30-2012, 01:11 AM   #20 (permalink)
Liked: 53 times
HighLifter has them for around 50-60 bux,and yes I would clutch one before I spent the much larger jack on a gr,and installation,the clutch kit is mandatory ...You can do the clutch(60bux),get an HMF(250ish),re jet(20buxish),get a K&N filter(60buxish),switch to all synthetics(40 bux),and snorkel (25bux) yer atv for less than most grs cost for the parts( let alone the installation if you're not able to do it),and be making more power,having a better clutch,sound,running atv with a higher top speed,and faster tire spin when in mud...If that isn't enough,then look into a gr...
2012 foreman 500 gear reduction
2012 honda foreman 500 gear reduction
2012 honda foreman gear reduction
gear reduction for honda 500 foreman
gear reduction for honda foreman 500
gear reduction honda foreman 500
honda atv gear reduction
honda foreman 500 gear reduction kit
