honda 300 ex carb problems!! - Honda ATV Forum
Old 08-23-2012, 03:02 AM   #1 (permalink)
zdw0889's Avatar
Member #22330
View zdw0889's Photo Gallery(0)
hey im new to the site and 4 wheelers got a 96 300ex on trade. guys said it was bored to 350 and big bore carb kit? i have cleaned the carb 3 times now and i still am not running right. after hour or two total ride time she dont want to run no more.it seem to not have power as it should when it does run. although last time it ran decent and seem to get better as i rode it. i have cleaned the tank put inline filter new fuel hose new vent hoses. my current jets are 100 and 42 from reading here i see that 100 is not right at all. so i will get a kit which do i get stage 1 or 2. and what is the recommended setup for what i have. no pipe just aftermarket can and k&n air filter. i have replaced spark plug oil filter and oil. have not done a compression test because my tester wont fit. thanks in advance for any replies
zdw0889 is offline   Reply With Quote
Old 08-27-2012, 06:01 AM   #2 (permalink)
eavery's Avatar
Member #11959
View eavery's Photo Gallery(0)
Well my 87 250x is 2mm overbore,stage 2 cam,uni multi stage air filter and stock pipe im running a 135 main and a 40 slow jet
eavery is offline   Reply With Quote
Old 08-27-2012, 09:26 AM   #3 (permalink)
KN11's Avatar
Member #20569
View KN11's Photo Gallery(0)
Friend of mine just had his problem with a 300 4x4 fixed with running issues. Even though in not very familiar with the 300 ex...Does yours run at all.... Or run very poor and cut out when giving it the gas?
Green '98 300 4x4 - Ole Reliable
Lift - With Front And Rear Adjustable Shocks
Cam
Clutch Kit
18% GR
12" ITP Wheels
26" Vampire ASX
Front Disk Brake Conversion
HID Lights
KN11 is offline   Reply With Quote
Old 08-27-2012, 01:17 PM   #4 (permalink)
all4honda's Avatar
Member #11937
View all4honda's Photo Gallery(0)
Look at the first sticky(by Josh) in this section. It should help with your jetting questions
all4honda is offline   Reply With Quote
Old 08-27-2012, 07:12 PM   #5 (permalink)
zdw0889's Avatar
Member #22330
It runs just no topend power boggs when you go to punch it.anif you sit with it at idle in neutral and punch the throttle it boggs horribly but it you go slow it does good.
Old 08-27-2012, 07:15 PM   #6 (permalink)
zdw0889's Avatar
Member #22330
Yea i did some real helpful info but when i went to look at jet kits it said 1,2,3 not sizes of jets so was wondering what stage my numbers would fall in
Old 09-02-2012, 05:03 PM   #7 (permalink)
zdw0889's Avatar
Member #22330
Ok i bought a jet kit with a 125 130 135 main and 42. with the 135 it runs a lil better at higher rpm. but now not so good at low. i have tried all my jets and i cant get it down spark plug has tan/brown color. i even tried a jet from my 440 snowmobile now no top end tons of low end. I'm stumped ive been messing with this for weeks now. getting frustrated. i really really dont want to pay someone to do it but I'm almost to that point. do i need to go higher on main or what.
Old 09-02-2012, 07:41 PM   #8 (permalink)
Liked: 53 times
Idle,and very low speeds is controlled by the pilot jet while the main jetting controls the past 1/4 to wide open throttle positions...Prolly need to step up the main again,and increase the pilot jet size one if it still hesitates at low throttle,or doesn't oull well just off idle...Also,check,inspect,clean,re oil the air filter if it isn't already clean,and freshly oiled...Welcome to da forums...
Old 09-03-2012, 08:51 AM   #9 (permalink)
Member #417
Liked: 304 times
YOu are going to need about a 140 main and pull the airbox lid off drop the slow to a 40. These are Keihin Hex sizes by the way about 2 3/4 turns out from lightly seated on the fuel screw and the needle in the 3rd clip setting
Old 09-05-2012, 08:17 PM   #10 (permalink)
zdw0889's Avatar
Member #22330
ok my air box doesnt have a lid. issue? my pilot is out 2 turns i am waiting on a new slide cause the guy that owned it before me stripped every screw on the carb. so i couldnt adjust the needle. but fixed most of them just not those little guys on the slide. needle is on the lowest setting now. so a 140 main and a 40 slow and needle at the 3rd setting and i should be good? can you clean k&n filters and reuse them or would it just be better to buy a new one mine looks pretty dirty?
300 ex carb
300 honda ex carbs
aftermarket honda 300 carburetor reviews
honda 300 carburetor kit
honda 300 ex
honda 300 ex carb
honda atv 300 carborator problems
honda atv 300 carbureator problems
honda atv 300 carburetor problems
honda300 ex
how to clean carburetor honda 300 ex
