450r carb on 400ex - Honda ATV Forum
Old 05-15-2012, 08:34 AM   #1 (permalink)
exrider1214's Avatar
Member #14128
View exrider1214's Photo Gallery(0)
450r carb on 400ex
Ok I have a 05 450r carb to put on my 400ex. I've tried it up there and it was super sluggish and it ran much better with the 400ex carb on it. My engine mods are a 416 bore with 12.5:1 compression stage 2 cam full hmf exhaust uni air filter. I need some netting suggestions I guess
04 kicker
Little bit of this little bit of that but a whole lot of fast
exrider1214 is offline   Reply With Quote
Old 05-15-2012, 11:59 AM   #2 (permalink)
Liked: 54 times
Netting suggestions>>Hold the rope between yer teeth while you hold the net up,and away from yer body while you spin around,and release the net in an arc out over the top of the fish,or school of fish,grabbing the rope from yer mouth before the line fully extends all the way out,taking yer teeth with it...As to jetting suggestions...I'd jet it to stock specs to start off with along with checking for vacuum leaks around the boots,set the air/fuel mixture screw to stock,then run it/ride it,and do a plug test were it me...
Old 05-15-2012, 01:04 PM   #3 (permalink)
Member #14128
No vacumm leaks as it runs perfect with the 400 carb. And as far as nets not fishing nets I'm talking trapeze nets. Im addicted to circus tricks and I'm a little heavy for regular nets
04 kicker
Old 05-15-2012, 01:56 PM   #4 (permalink)
Liked: 54 times
I'd run the 400 carb if it runs perfect on it then...
Old 05-15-2012, 02:49 PM   #5 (permalink)
Member #417
Liked: 305 times
ok you have to realize you increased the airflow by 6mm therefore the main jetting and slow jetting will have to be increased. Start with a 45 slow and see how the low side is running. As far a a guesstimate on the main try a 180 and run a plug test.
For the netting Mr. Thabush described if you make small loops roughly 10" like rolling up an extension cord then grab the net about 1/3 the way down in the same hand while holding the rope, now about 18" down grab the net with your other hand and stick the weighted rope in your mouth, extand your free had back down all the way and grab the net. Rear back and give her a good toos almost like throwing a big frisbee. release the net and let her fly as soon as it hits the water count to 3 and pull. lol
Old 05-15-2012, 03:39 PM   #6 (permalink)
Member #14128
I really want the 450 carb seeing how I already bought it and people say it increases torque big time. Plus I said I like circus tricks not fishing guys get with it!!!!! Lol
04 kicker
Old 05-15-2012, 05:57 PM   #7 (permalink)
Liked: 54 times
Welp,we live on the coasts,not inland lubbers,we do what is local....As to circus tricks,I don't know about all that now...I'd try what da Moose suggested with the jets before I tried anything else...
Old 05-15-2012, 06:52 PM   #8 (permalink)
Member #14128
Yea I'm pretty sure its the jets.. and as far as the coast I live an hour away so I'm definately no inlander!!! Hahaha I really want to get it squared away I still have a few loose ends to tie up
04 kicker
Old 05-22-2012, 08:02 PM   #9 (permalink)
SlammedRanger's Avatar
Member #1963
View SlammedRanger's Photo Gallery(0)
Liked: 178 times
I'm going through the head ache of tunning the 450r carb on my quad aswell. I thought I had it with the 50 pilot and 200 main. Then I made two laps and it started cutting out bad. I then pulles it apart to find the choke somehow got bumped and on. I am now going for a 52 pilot and I'm at a 180 main. I'm just jetting up till it stops popping on decel. As for the pilot jumps I've made I had the 50 in at 3 1/2 turns on mix to run ok. Still coughing through carb if I just bump the throttle slightly. So 52 and 2 1/2 turns is what I'm trying next. Hope this helps and your not alone brother its a headache doing this mod. But the power is sooooo worth it. This 450r carb eats!
07 416ex
Wiseco 11:1 87mm piston
Stage 2 magnum cam
Kibble white +1mm valves (high rev springs)
P@P
Crf450 t-chain
Cometic gaskets
Gt thunder hd studs
EBC Dirt Racer Clutch
PRM skid
Hmf slip-on-dg header
UNI filter with ehs powerlid
45 pilot, 1 3/4 turns, middle clip, 188 main
razr XC tires
Team Alba (bumper,nerfs,beadlocks,+2 lt arms)
Mod quad dash
Acerbies handguards
Msr ez pull lever
Oury grips
Pro taper fat bars
TCS triple rate front shocks
PEP rear shock
SlammedRanger is offline   Reply With Quote
Old 05-22-2012, 08:05 PM   #10 (permalink)
Member #417
Liked: 305 times
Larger carbs are always a Bitch. my 400 carb on my 250x was. lol
400ex 450r carb
400ex 450r carb swap
400ex carb mod
400ex carb mods
400ex carb swap
450r carb on 400ex
99 400ex 450 carb how to set carb to run
honda 400ex carb
honda 400ex carburetor
honda 450ex carburetor
honda 450r carb
new honda 450r carb
