clutch kit - Honda ATV Forum
post #1 of 6 (permalink) Old 04-03-2012, 07:13 AM Thread Starter
HondaGuy300's Avatar
clutch kit
okay, supid question, when you get a clutch kit for running larger tires, what does it actually do to the atv? Do you have to pull in a clutch lever like a dirt bike?
Honda Rancher 420 4x4 ES w/ EPS (red)
completly stock (for now)
[CENTER]gone but not forgotten: Honda Fourtrax 300 4x4
HondaGuy300 is offline
post #2 of 6 (permalink) Old 04-03-2012, 11:34 PM
No, it doesn't convert it into a manual clutch. All the clutch kit consists of is, stronger springs for the centrifugal clutch. All it does is, it raises the stall speed, it just lets the engine rev higher before the centrifugal clutch engages.
post #3 of 6 (permalink) Old 04-03-2012, 11:41 PM
wheeler's Avatar
Liked: 120 times
Very well said Helmut!
1995 Honda 300, 355bbk, 40b Webcam, Springs & Hardened Rockers, FMF Full Exhaust, EBC DRC Clutch Kit, Outlaw Clutch Springs, 138 Main 42 Slow Jets, 2nd Clip on Needle, Twin Air Filter, HL Disc Brake Conversion, Wide Open 424 kit, HL 2" lift, 26x10x12 Executioners, Terra 35 Super Winch, Heat Demon Hand/Thumb Warmers, Powermadd Hand Guards, PIAA 35w Bulbs
http://www.hondaatvforums.net/forums...-big-bore.html
wheeler is online now
post #4 of 6 (permalink) Old 04-04-2012, 11:46 AM Thread Starter
Thanks guys
post #5 of 6 (permalink) Old 04-05-2012, 01:07 AM
You're welcome.
post #6 of 6 (permalink) Old 04-05-2012, 07:09 AM
Fourtrax's Avatar
If you are going to go inside there for that I would recommend changing to stiffer springs on your change clutch and new plates for it as well. Might as well kill two birds with one stone. The stiffer springs on the change clutch help to eliminate slipping when you shift especially with the bigger tires. I put stiffer change clutch springs and new plates in mine when I had it apart and it made a huge difference in the stiffness of it. The lever is a little harder to move due to the stiffer springs but it snaps right into gear with no slipping AT ALL.
1988 FourTrax 300
Fourtrax is offline
