300 ex timing - Honda ATV Forum
Old 01-26-2012, 07:13 PM   #1 (permalink)
ritenour's Avatar
Member #12154
View ritenour's Photo Gallery(0)
300 ex timing
what is the easiest way to check the timing on a 2006 300ex. just put a stage 2 web cam in it starts up and stays running but when you hit the throttle it stahls out.
ritenour is offline   Reply With Quote
Old 01-27-2012, 07:34 AM   #2 (permalink)
Tippmann98's Avatar
Member #15501
View Tippmann98's Photo Gallery(0)
Take the valve cover off and take the timing plugs out. Use a 17mm socket and turn the flywheel counter clockwise til you find a sideways T followed by a straight up and down line. You want that line to be lined up with the notch in the timing hole. Once that is all lined up, go to the other side of the quad and look at your camshaft sprocket. Both lines on the sprocket should be parralel to the head. The lobes should be pointing down.
Tippmann98 is offline   Reply With Quote
Old 01-27-2012, 05:38 PM   #3 (permalink)
X2 on this. ↑↑↑↑↑ And welcome to the forums, ritenour.
Old 01-27-2012, 06:59 PM   #4 (permalink)
ritenour's Avatar
Member #12154
i took the timing plugs out in the little hole was an arrow. i turned the 17mm bolt counter clockwise and foud two lines. so i lined up the arrow in between the two lines and the lines on the cam sproket are parellal with on another but still doin the same thing.
Old 01-27-2012, 07:03 PM   #5 (permalink)
dbell1's Avatar
Member #8172
View dbell1's Photo Gallery(0)
You need to line the notch up with the line with the "T" next to it
dbell1 is offline   Reply With Quote
Old 01-27-2012, 07:06 PM   #6 (permalink)
X2, line it up with the line right beside the "T". The two marks that are side by side are used to check the ignition timing, not the cam timing.
Old 01-27-2012, 07:32 PM   #7 (permalink)
dbell1's Avatar
Member #8172
And make sure there is play in the valves when you have the flywheel on the "T" so you know it is TDC
Old 01-27-2012, 07:46 PM   #8 (permalink)
ritenour's Avatar
Member #12154
okay got the side ways t mark lined up with the arrow now on the cam side the lines are not pefectlly parallel with one another i tried to wove the cam gear to line them up perfect but it wont does will this effect anything?
Old 01-27-2012, 08:16 PM   #9 (permalink)
dbell1's Avatar
Member #8172
My 400ex is the same way. Just try moving the chain one link in each direction and if that makes it WAY off then go back to the original position. Sometimes it doesn't line up just perfect.
Old 01-27-2012, 09:16 PM   #10 (permalink)
X2, sometimes the two lines won't line up perfectly with the edge of the head, but they should be close. The more the timing chain is stretched, the more the lines will be off.
300 ex timing
300 ex timing marks dont line up perfectly
300ex cam sprocket timing
300ex timing marks
96 honda 300 ex timeing
honda 300 ex timing marks
honda 300ex timing marks
honda ex 300 timing specs
how to check timing on honda 300
how to set the timing on a 300ex
pic timeing marks 300 honda ex
timing marks honda 300 ex
