Reverse lockout override - Honda ATV Forum
Old 06-14-2011, 09:38 AM   #1 (permalink)
Liked: 53 times
I found this awhile back,and made one according to this video,and it works great... ...Since I am unable to get from forward gear to reverse without going through neutral,and I always stop,and engage the brakes when doing any direction changes(cept when in mud,and not moving) it helps with much quicker,less fumblesome reverse changes...
Old 06-14-2011, 03:18 PM   #2 (permalink)
You can do the same thing by just adjusting the cable. Loosen the lock nut and adjust the cable until it pulls the lever up and then tighten the lock nut back down and you're done. Takes less than 30 seconds.
Old 06-14-2011, 05:01 PM   #3 (permalink)
Liked: 53 times
Dang,and I spent 30 minutes getting the tools out,rounding up the wood,laying it out,etc...Where's the lock nut,and adjuster located at?
Old 06-14-2011, 05:20 PM   #4 (permalink)
Depends on which model you have, but it will be on one end of the reverse cable. On the Fourtrax 300, it's located down near the right foot peg, near the reverse lockout lever. On most of the newer ATVs, it's located on the other end of the cable, near the left hand brake lever.
Old 06-14-2011, 05:23 PM   #5 (permalink)
Liked: 53 times
Cool,thanks...
Old 06-14-2011, 05:24 PM   #6 (permalink)
bobs330's Avatar
Member #8144
seems like a safety thing to me?
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
Old 06-14-2011, 05:28 PM   #7 (permalink)
Cool,thanks...
No problem. If it's a 500 Foreman, like in the video, the adjustment is at the end of the cable where it hooks to the left hand brake/reverse lever. Just adjust the cable out to make the outer sheath or the cable longer and it will pull the reverse lockout lever up. Then, just tighten the lock nut back down. That's the first thing I do to every Honda I get.
Old 06-14-2011, 05:55 PM   #8 (permalink)
Liked: 53 times
It was for the 500. I made 2 of them originally..The 1st one split,and fell out,the 2nd one is still in there almost a year later ...Gonna do away with it,and adjust the cable next time I'm fooling with the 500...
Old 06-14-2011, 05:57 PM   #9 (permalink)
jandj's Avatar
Member #9841
View jandj's Photo Gallery(0)
You can also use a piece of large size vaccum hose. This also works on ranchers, could possibly work on anything with that stupid button. And if you have kids you pull it out and they have to think a little bit!
  • 08 Rancher es SRA
  • 2500# Mile Marker
  • AME Heated Grips
  • 25" Power Grips
  • ATVTEC Rear Bag
  • 08 Polaris 500efi
  • 2500# Mile Marker
  • 26" PXT Wheels
  • Polaris Rear Box
jandj is offline   Reply With Quote
brake override honda rancher reverse
by pass reverse button on honda foreman
honda atv reverse lock out clip
honda atv reverse override
honda foreman reverse button override
honda foreman reverse override
honda fourtrax reverse overide
honda rancher wedge
honda reverse button override
honda safety reverse lockout
rancher es reverse switch override
where is the reverse lockout lever on a2001 honda rancher four wheeler
