trx450es shifting problems - Honda ATV Forum
post #1 of 10 (permalink) Old 11-24-2010, 04:58 PM Thread Starter
oldyelr51's Avatar
hello, i am the owner of a 2000 trx450es with 2900 work,mud and enjoyable trail miles.(very tough and reliable machine!) I do not have reverse anymore (worked in the a.m. and didn't work in the afternoon) and i am looking for suggestions as to what might have happened and how to fix it. The shifter solenoid still "clicks" and i still have forward gears. Is this the right place to post this message? Thanks
oldyelr51 is offline
post #2 of 10 (permalink) Old 11-24-2010, 05:25 PM
Welcome to the forums. Have you tried to shift into reverse manually by using the manual shifter that came with the ATV? If you can't shift into reverse manually, you may need to adjust your reverse lockout cable. The cable might not be pulling the reverse lever up all the way when you push the red button and pull in the brake lever.
post #3 of 10 (permalink) Old 11-24-2010, 05:39 PM
mud99's Avatar
My Rides
2002 F-250 4x4
250R
www.trxforums.com
mud99 is offline
post #4 of 10 (permalink) Old 11-24-2010, 06:34 PM Thread Starter
oldyelr51's Avatar
I will try this and let you know how i make out, thanks!
post #5 of 10 (permalink) Old 11-24-2010, 06:52 PM Thread Starter
oldyelr51's Avatar
i did try the
manual shifter and.....no luck it still will not shift into reverse...the neutral light will go out for a second but as soon as you let go of the shifter it will come back on
post #6 of 10 (permalink) Old 11-24-2010, 06:59 PM
Originally Posted by oldyelr51 View Post
i did try the
You had the red button pushed in and the brake lever pulled back while you were trying to manually shift into reverse, right? If so, I would try adjusting the reverse lockout cable. It might not be pulling the reverse lever up enough for it to go into reverse. Also, try rocking the ATV back and forth a little while you're trying to shift it into reverse.
ADDED: If it goes into reverse when rocking it, you need to adjust the clutch freeplay.
post #7 of 10 (permalink) Old 11-24-2010, 07:43 PM Thread Starter
oldyelr51's Avatar
k, back to the garage
post #8 of 10 (permalink) Old 11-24-2010, 08:06 PM Thread Starter
oldyelr51's Avatar
I pressed the red button and pulled the lever, it makes the manual shift lever on the side move but does not go into reverse.Rocking the machine and/or adjusting the cable does not make a difference either. Any other suggestionsare greatly appreciated. I will check tomorrrow,thanks. Have a nice holiday.
post #9 of 10 (permalink) Old 12-28-2016, 11:22 PM
Dreaded's Avatar
New to Forums
Hi My name is curtis and I have electric shifter problems on a TRX450es.
Dreaded is offline
post #10 of 10 (permalink) Old 12-28-2016, 11:25 PM
Liked: 1870 times
welcome, please post a thread in the repair section. oh, and this thread is older than dirt..lol.
