2004 honda rancher es 4x4 shift problem - Honda ATV Forum
Old 01-14-2013, 03:46 PM   #1 (permalink)
hodges81's Avatar
Member #27882
View hodges81's Photo Gallery(0)
it will shift once when you turn on the ignition then it wont shift any more. almost as if it looses power. if you turn the ignition off and then on again it will shift once again.
hodges81 is offline   Reply With Quote
Old 01-14-2013, 04:21 PM   #2 (permalink)
Liked: 52 times
Welcome to da forums... I'd start by having the battery load tested after trickle charging it at 1.5 amps,or less until it is peak charged...If the battery is bad,or weak,replace it with a new of the same group size,or larger...Next I would check all connections on the machine by unplugging every one of them,spraying electrical cleaner through each plug several times,add a dab of dielectrical grease to each female connector before plugging back together...Next I would remove the shift motor,disassemble it,clean using spray electrical cleaner several times,add a dab of dielectrical grease to each end bushing/bearing,and reassemble,bench test it...Reach a finger,or screwdriver into the shift motor housing,and turn the reduction gear inside there several turns ccw,if it stops,and won;t turn any further,turn it the opposite direction that number of turns,plus several more,reinstall the shift motor,remove the shift sensor,clean the end of it off,dab very very thing coating of dielectric grease across the contact area,reinstall,clean the sensor plug...
2004 honda es wont shift
2004 honda rancher 350 shifter problems
2004 honda rancher 400 electric shifter
2004 honda rancher 400 electronic shift trouble shoot
2004 honda rancher electric shift problems
2004 honda rancher es shifting problems
2004 honda rancher es wont shift
2004 honda rancher not shifting
2004 honda rancher shift problems
2004 honda rancher shifting problems
electric shift 2004 honda rancher
shift problems on 2004 honda rancher at atv
