86 honda 200sx - Honda ATV Forum
Old 04-26-2012, 07:09 AM   #1 (permalink)
bubsstang88's Avatar
Member #18194
View bubsstang88's Photo Gallery(0)
86 honda 200sx
hello all,I am new here,I am trying to fix up an old honda 200sx and was wandering if there was a way to swap out the front hubs to run a 4x110 lug pattern and any shock/lift ideas for this machine.thanks
bubsstang88 is offline   Reply With Quote
Old 05-04-2012, 07:34 AM   #2 (permalink)
Member #18194
I guess no one could help me with that so here is few more questions,does anyone know what is the recommended oil and filter and how hard is it to change the filter and i have been noticing that after riding for a while when the engine is good and hot the(I guess you call it the clutch) starts slipping a little,no shifting problems but the engine revs faster than the it goes,any suggestions
Old 05-04-2012, 11:43 PM   #3 (permalink)
The 200SX doesn't really have a conventional oil filter like most models. It has a screen inside the engine and it just has a piece that bolts to the end of the centrifugal clutch that you have to unbolt and wipe off with a cloth. The crankcase cover has to be removed to clean both of these. Click on the link below and you can download the service manual for more details.
Honda_Trx200sx_Service_Manual_Repair_1986-1988.pdf
Old 05-04-2012, 11:45 PM   #4 (permalink)
And welcome to the forums.
Old 05-05-2012, 01:06 AM   #5 (permalink)
Liked: 54 times
Make certain that you run a wet clutch compatible oil,or else the clutch will slip,and go out...You can adjust the clutch on it by loosening the clutch adjustment nut,gently turning the screw ccw inwards until it stops,then backing it outwards 1/4 of a turn,holding it with screwdriver while locking the lock nut back down...Do a short change on the oil(change it,run it for half an hour,or so,then drain it again while the oils still good n warm will help clean out the bottom end including the transmission,and clutch)...As to a lift,you can build,or buy shock spring spacers which when installed on the shock under the bottom of the spring will only lift the atv upwards the amount of down travel the shocks have...How much you can pick the front end up before the shocks are fully extended..Maybe 1".or 1.5" would be the max lift on the front if that...If you want a 4/110 bolt pattern up front,order a pair of adapters off feeBay for around 60 bux...
Old 05-05-2012, 02:33 AM   #6 (permalink)
CavemanTiny's Avatar
Member #17696
View CavemanTiny's Photo Gallery(0)
Ahh, '86 200sx brings back fond memories. Welcom to the forums.
'12 Rincon, stealth snorkel, K&N air filter, 27" Mud Lites, custom made sound tube
'11 Foreman, 27" Mud Lites
'03 Rancher, HMF, Cam, clutch kit, 28" Mega Mayhems
CavemanTiny is offline   Reply With Quote
Old 05-06-2012, 07:14 AM   #7 (permalink)
Member #18194
thanx for the info
Old 05-06-2012, 10:00 AM   #8 (permalink)
Mudslinger11's Avatar
Member #16417
View Mudslinger11's Photo Gallery(0)
Welcome from NW Florida
2011 Honda Rancher 420 2x4
In The Mud
Mudslinger11 is offline   Reply With Quote
200 sx honda quad trans oil
200sx honda
200sx honda atv
86 honda 200sx
86 honda 200sx oil
honda 200 sx
honda 200sx
honda 200sx clutch adjustment
honda 200sx oil
honda 200sx oil change
honda 200sx oil filter
honda fourtrax 200sx oil filter
