10-19-2011, 07:03 PM
#1 (permalink)
Member #13658
Location: Farmington, ct ride primarily in Bristol CT, amazing trails
My chain on 2007 trx300ex keeps falling off, why?
one day i pulled my brother on a sled to my quad and then heard a loud noise. the next day, i saw the chain was very loose and the pinch bolts were loose so i tightened both things and i went riding in the woods on rocky terrain and it just kept on falling off. The thing that ajust the tightnest would sometimes loosen or the chian would just normally fall off. i heard i eighter need new bearings or new sprockets and chain. Also, can you list some tests i can do to see which i would need to do.
10-19-2011, 07:14 PM
#2 (permalink)
Member #988
Look at the sprocket to see how the teeth look. If they are rounded off its more than likely worn out. Welcome to the forums
www.bbnradio.org
Our rides
1995 Wrangler
2004 Ford Explorer
2004 Recon 250
2009 Troy Built Lawn Tractor
and a 110 Pink Panther
www.trxforums.com
10-19-2011, 07:21 PM
#3 (permalink)
Member #805
Agreed^^^ check sprockets and chain, check any rollers that mar also be worn out
10-19-2011, 07:47 PM
#4 (permalink)
Welcome to the forums.
10-19-2011, 07:51 PM
#5 (permalink)
Member #4493
Welcome from the Volunteer state.
2004 Rincon
2" lift
27" mudlites, ITP SS212's
Mud bike
2004 Rancher 400AT
Bone stock
Hunting and trail bike.
10-19-2011, 11:47 PM
#6 (permalink)
Member #8548
Welcome from Georgia!
2003 rancher 350 - 2002 trx 300ex - 1999 ltf 300f - 1986 trx 70. - 1984 atc 70-
10-20-2011, 04:57 PM
#7 (permalink)
Member #12562
welcome. jack up the rear of the atv. with the wheels off the ground try to move the axle and feel for play in the bearings. also, make sure the carrier is all the way in the swingarm, if it's not seated all the way against the swingarm your sprockets will not be lined up and cause the chain to come off.
1999 pain in the a** and 2007 pain in the neck
My ATV Website
10-20-2011, 04:58 PM
#8 (permalink)
Member #12562
also, check the swingarm bearings, where the swingarm connects to the frame.
My ATV Website
10-20-2011, 05:22 PM
#9 (permalink)
Member #13305
yes welcome to the forums. i am with mudd99. it is amazing how sesative the sprock gears are on every thing. a rounded off sprockets gear is critical. its just as important as any micro play in a berring asemblys.
10-20-2011, 05:51 PM
#10 (permalink)
Member #9942
09 Honda recon 250es dunlop tires, gun racks
09 Honda Foreman 500es Kenda executioners coleman gun racks, stearns spotlight, kolpin hand guards, and warn rt25
2001 polaris sportsman 500 h.o. warn winch rack extenders
2006 400ex protaper se, razr 2, lamin light film, twin air air filter, pro armor nerf bars, motoworks sr4 slip on, jet kit, d.i.d chain, 36t rear sprocket. she goes braap braap
2007 trx300ex, 300ex chain keeps popping, 400ex chain coming off, atv chain keeps coming off, atv chain keeps popping, chain keeps coming off 4 wheeler, chain keeps falling off atv, my chain keeps comming off my atv, tire keeps falling of axles on four wheeler, why does my 400ex chain keep loosening?, why does my chain on my fourwheeler keep falling off, why is my quad chain falling off
