No neutral light 300ex - Honda ATV Forum
Old 08-18-2011, 11:16 PM   #1 (permalink)
daduck's Avatar
Member #12365
View daduck's Photo Gallery(0)
I have a 2003 300ex. I bought from a guy who put after market handle bars on it and when I bought it it had no headlight, neutral, or reverse light hooked up. I put the headlight back on (works fine). I then replaced the neutral and reverse lights but neither one work. I do not know much about the wiring and cant figure out why they dont work. The quad will not start in reverse, so I assume that part is still hooked up. Any ideas what he could have done? Checked both lights also and they work, so its not the bulbs.
daduck is offline   Reply With Quote
Old 08-18-2011, 11:54 PM   #2 (permalink)
Liked: 53 times
Howdy,and welcome to the forums...Free downloadable electronic manuals in the Schematics/Manuals section in here...Check the wiring schematics in the manual available in here to see what wires goes where...
Old 08-19-2011, 12:00 AM   #3 (permalink)
Welcome to the forums. I agree with Deep and make sure the wires are plugged into the neutral and reverse switches.
Old 08-19-2011, 12:01 AM   #4 (permalink)
mud99's Avatar
Member #988
View mud99's Photo Gallery(0)
You may want to check the wiring. Welcome to the forums.
My Rides
2002 F-250 4x4
250R
www.trxforums.com
mud99 is offline   Reply With Quote
Old 08-19-2011, 01:20 AM   #5 (permalink)
daduck's Avatar
Member #12365
Everything appears to be in the right place and hooked up. The reverse and neutral switches are hooked up with good clean connection. Could it be a bad reverse inhibitor?? Everything works normal (wont start in reverse, wont start in gear w/out clutch pulled in and starts fine in neutral). The only thing not working right are the reverse and neutral lights??? I have power to both of them threw the black wire, its like its not grounding when its in neutral or reverse. And it will not start with neutral or reverse switches unplugged(I tried it when I checked the connections), so I assume they are working ok.
Old 08-19-2011, 07:03 AM   #6 (permalink)
Melatv's Avatar
Member #11544
View Melatv's Photo Gallery(0)
Liked: 117 times
Ok -- Remove the wire from the neutral switch and ground that wire to the frame, the neutral light should be on (key switch on). Grounding the wire is just a test remove it after. Then do the same for the reverse switch. Also when the bike is in neutral you can check the switch --- with your meter from the switch to the frame you should get continuity. Do the same for the reverse switch.
Are both wire connected to each light -- should be 2 wires on each light, you have said you have power on the black wire, follow the wire from the other side of the light it should be connected all the way to the reverse inhibitor ( both light end up there).
25" Kenda K587 Bear Claws HTR
2500 Runva Winch
Melatv is offline   Reply With Quote
Old 08-19-2011, 10:38 AM   #7 (permalink)
Member #417
Liked: 304 times
Agree ^^^^^^ Welcome to the forums
Old 08-25-2011, 02:58 PM   #8 (permalink)
daduck's Avatar
Member #12365
Here is what I have: The neutral switch grounds when its in neutral, and looses its ground in gear. The reverse switch is grounded and looses its ground when in reverse, and the neutral switch stays grounded while in reverse? This stays the same all the way to the reverse inhibitor, but neither light works?? They are both hooked up to the correct wires. I am totally lost. I took the wire off of neutral and reverse switches and grounded them to a good ground, one at a time, and no lights!! My last guess is a bad reverse inhibitor box.
Old 10-20-2012, 06:52 PM   #9 (permalink)
tecate1987's Avatar
Member #15417
View tecate1987's Photo Gallery(0)
same issue
I know this is an old post but I am having the exact same problem No neutral light or reverse light. quad starts and runs fine. I have power to the black wires up near the lights but no lights, Bulbs are good.
If I switch the wires on the sensors near the brake pedal the reverse light comes on and stays on at all times.
any ideas??? help
tecate1987 is offline   Reply With Quote
1995 handa 300ex reverse inhibitor module what wiring and parts are connected
2003 honda trx300ex neutral indicator light bypass
300 ex headlights work but the neutral and reverse light wont work the bubs are good
300 ex the neutral. and reverse light wont come on and bulbs are good
300ex neutral light
300ex neutral switch
300ex no neutral light
honda 300ex neutral light
honda 300ex neutral light not working
how to ground reverse and neutral switches on 93 honda 300ex?
how to wire headlight without original light on 300ex honda
trx300ex wont start reverse light stays on
