Stuck in gear. No shift. Neutral light on. - Honda ATV Forum
Old 02-15-2011, 03:46 PM   #1 (permalink)
jethroish's Avatar
Member #8571
View jethroish's Photo Gallery(0)
New to the forum
2003 Recon TRX250 TM. Changed oil last week with syn. non-energy conserving oil. Been running fine. Was riding. Shut it off. upon restarting, heard a "pop"
Now the neutral light is on and it is stuck in gear (3rd i think). It starts and drives, but WILL NOT SHIFT. Won't go up or down. Won't go to reverse.
neutral light stays on. Push the shifter and the clutch allows the rear wheels to turn freely.
HELP
jethroish is offline   Reply With Quote
Old 02-15-2011, 03:56 PM   #2 (permalink)
Welcome to the forums. I don't know that much about the transmission on a Recon, but I'm assuming they're similar to other models. You may have a broken shift drum, but I would pull the front cover and inspect the shift linkage first to be sure that it's not just the linkage. The fact that the neutral light is staying on and it won't shift gears makes me think it's a broken shift drum, since the end of the shift drum turns the gear position switch to indicate whether it's in neutral or not. Like I said, it could just be the shift linkage under the front cover, but it's the "pop" that worries me.
Remove the front crankcase cover and inspect the shift linkage and make sure it's turning the shift drum. If the shift linkage is turning the shift drum, the other end of the shift drum is likely broken.
Old 02-24-2011, 03:21 PM   #3 (permalink)
jethroish's Avatar
Member #8571
Finally got it all apart. A piece broke off the shift drum.
Old 02-24-2011, 03:23 PM   #4 (permalink)
I figured it was something to do with the shift drum, because the end of the shift drum operates the neutral light.
4 wheeler stuck in gear
90 model 300 honda 2 wheeler drive stuck in reverse
gear is stuck on 4 wheeler
gear shifter on four wheeler broken
honda 4 wheeler stuck in gear
honda 90 4 wheeler not shifting
honda recon shifter stuck down
honda recon stuck in 3 gear with neutral light on trx tm 2002
honda recon stuck in gear
honda recon stuck in reverse
shifter won't move, wheels locked on 4 wheeler
when neutral light is on the 2001 honda 4 wheeler is in 3rd gear
