TRX 300 no spark - Page 2 - Honda ATV Forum
post #11 of 16 (permalink) Old 01-24-2011, 09:33 PM
Liked: 204 times
helmut is right, i was always taught to check and make sure everything is good BEFORE buying a new CDI. they say those are the last things to go tits. i hope you can find out soon, thats gotta suck. also ebay sells alot of used CDI's if you decide to replace it, but then you run the chance of that going bad prematurely.
Manny is offline
post #12 of 16 (permalink) Old 01-25-2011, 04:29 PM
my5sons's Avatar
Originally Posted by Helmut View Post
You may have a bad ignition component. Test your ignition coil, pulse generator, and stator. If all these test good, you may have a bad CDI. If you don't have a service manual, click on the link below to download the factory service manual. It will show you how to test the ignition components.
Honda TRX300 and TRX300FW Service Shop Repair Manual_88-94, except FW skips 89 model.pdf
Just an FYI, on a TRX250EX, I tried testing the coil, pulse generator and stator. Didn't even get past the coil before realizing that a $150 fluke meter (10 years old) couldn't do peak voltage measurements. I needed a peak voltage adapter. Hope you have one.
You can follow the details here: It started as a carb problem, and ended with a no spark condition...
06 TRX250EX carburetor
2001 Suzuki LT A50
2003 TRX300EX
2006 TRX250EX - Maxxis Razrs
my5sons is offline
post #13 of 16 (permalink) Old 01-25-2011, 04:43 PM
You can test the components on some of the older models with just an ohmmeter. The factory service manual for the '91 Fourtrax 300 lists the specs in ohms, so you can use an ohmmeter. In the newer manuals, almost all the tests have to be done with a peak voltage tester, because the manual lists the specs in peak voltage. I guess checking the peak voltage is a more accurate method of testing. That must be why they changed to that method.
post #14 of 16 (permalink) Old 01-25-2011, 05:13 PM
my5sons's Avatar
Cool stuff, I dl'd the manual and am going to check it against my 06 TRX250EX manual. Just want to see if I can ohm anything out. Interesting that in this manual they lean more towards testing the CDI first right?
2001 Suzuki LT A50
2003 TRX300EX
my5sons is offline
post #15 of 16 (permalink) Old 01-25-2011, 05:21 PM
Yeah, I think they've found out that it's hard to accurately test the CDI, since that manual was published. Or that would be my guess anyway. I think most of the newer manuals say to test the other ignition components first and then replace the CDI if the other ignition components test good.
post #16 of 16 (permalink) Old 01-27-2011, 01:21 PM Thread Starter
gleck's Avatar
Thanks everybody
gleck is offline
