11-22-2010, 09:01 PM
#51 (permalink)
Originally Posted by 86trx
well, im going to look for a coil to borrow. i dont want to buy one just yet as ive already gone way over-budget on this machine.
if and when i do find the problem ill be sure to post back on what it was. i wouldnt want anyone else to spend what i did and NOT resolve the problem.
thanks again Helmut for all your help, patience, and prompt replies. it was much appreceiated..
Yes, I understand, no one wants to buy something they don't need. Good luck and I wish I could have helped you more.
12-09-2010, 01:43 PM
#52 (permalink)
Member #5775
Well, i got brave enough and tore into it again. took the chain and everything out, then reinstalled it. and this time it was dead on! so, i put it all back together again. and it runs beautifully! no misfires, smooth and steady and all kinds of power! although the is still a little hesitation there, but with the way it runs now im sure i can live with it! I just stopped in to let you know that with your guidence i finally got this running the way a Honda should! now with that outta the way i can finally start on my 1964 Honda CA77. thanks again!
12-09-2010, 01:47 PM
#53 (permalink)
That's great, I'm glad you got it fixed!!!
03-22-2011, 04:15 PM
#54 (permalink)
Member #9245
hey everyone,
i have a weak spark on my 86 trx 250 fourtrax. i have changed the stator and flywheel as well as the pulse generator along with a new plug.....still weak. ive checked the resistance of the primary side of the ignition coil and its showing me 0.4 - 0.5 ohm. the service book however states resistance should be 0.16 - 0.2 ohm. could this be the cause of the weak spark?
thanks to everyone in advance..
Just a heads up... (If you're still interested...) I have an 84 tRX 200 that had the same problem and the cause was a faulty ignition switch. Wear and tear I guess, but I just left the key to the 'on' position (to prevent any conflicting signals to system) and then snipped the 2 'on' wires running to the switch and soldered them together. Awesome spark resulted.
It's worth checking, just for fun...
1986 honda hulix got weak spark, 86 fourtrax 250 weak spark, 86 honda 250 valve cover, 90 300 fourtrax weak fire, 99 honda trx 300 what does a bad cam look like, atv weak spark, can bad coil cause weak spark four wheeler, honda fourtrax 250 cam timing, honda fourtrax 300 marking on timing chain sprocket and cam, honda trx 250 weak spark, weak spark symptoms, what cause weak firing to spark plug on a 1986 honda 250 fourtrax
