Honda 300 coil testing - Honda ATV Forum
Old 08-20-2013, 12:54 PM   #1 (permalink)
HOPEULIKIT MUDDER's Avatar
Member #4444
View HOPEULIKIT MUDDER's Photo Gallery(0)
I've been building up a big 300 lift 29.5 ol2's body lift bored .30 over wiesco piston kit, 54% gr, head work fo-4 exhuast, strectched big red cam, yea im probably missing some. And a New battery
well to the question the bike is complete i went to crank it and the nuetral light wouldnt come on well i had to ground the wire got that now it turns over good, but as far as i know im not getting fire.
wats the best way to test the coil to find out???
would a test light hooked to the ground on the battery and stuck in the spark plug boot do it!!!
HOPEULIKIT MUDDER is offline   Reply With Quote
Old 08-20-2013, 03:43 PM   #2 (permalink)
Member #4444
come on now i know somebody knows how to test a coil.
Old 08-20-2013, 04:02 PM   #3 (permalink)
b52bombardier1's Avatar
Member #31787
View b52bombardier1's Photo Gallery(0)
Liked: 245 times
That would only let all of the analog smoke out of your test light!!
There are tests out there looking for specific values of resistance in ohms between the various coil wires and ground. These indicate whether you have broken wires in the coil or perhaps the enamel insulation on the wire is breaking down. These tests are usually done with the plug cap removed so that any resistance there is NOT part of the circuit under test.
The problem here is that every different part number for coils has different values for resistance which makes stating absolute values for any particular type of coil impossible. I have resistance values for my 70's Honda minibike engine coils but that will not help us here.
I will say this - most coils do not fail internally. Usually, it is a broken wire that can be fixed with a high tension wire splice kit. Or, the plug cap fails open with infinite resistance (due to trapped rusty water) on a continuity test on a multimeter - simply get a new plug cap.
I have also "repaired" coils by removing the plug cap and then nipping a quarter inch of the wire off and then reinstalling the cap. Rusty water can wick its way up the wire and kill the spark.
Rick
2006 Green Honda Foreman 500 - Viper Elite Winch
2004 Yellow Honda 250ex - Grandson's Bike
1971 School Bus Yellow "Spaghetti" Harley-D Sprint 350
1972 Candy Yellow Honda CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green Honda ST90 K0
1974 Mars Orange Honda CT90 K5
1975 Topaz Orange Honda ST90 K2
1976 Shiny Orange Honda CT90
b52bombardier1 is offline   Reply With Quote
Old 08-20-2013, 05:44 PM   #4 (permalink)
Member #4444
ok thanks so just pull the red boot off and clip a lil' then try her agin??
i love my 300's just hate dang electrical stuff which usualy never have electrical problems.
Old 08-20-2013, 10:13 PM   #5 (permalink)
Member #31787
Liked: 245 times
You can try cutting a little off the high tension wire. Just be careful to not damage the plug boot.
How do you know you are not getting spark?? Are you laying the spark plug against an engine cooling fin and cranking the engine to see if you see a spark at the gap? In a dark garage, you can really get a good look and hope to see a fat blue spark.
Rick
Old 08-21-2013, 09:09 PM   #6 (permalink)
Member #4444
Yea I've tried it on a fin and no spark then I pulled the boot off and when I did the plug wire came rite out Is it not connected to the piece inside the boot and wat exactly are y'all talking about cutting I cut te rubber back on the wire there is wat looks wire some wire w a loop. I may be sounding stupid but I've never pulled a plug boot off and dnt know wat to do w cutting the wire. Shoot this thing was a frame less than 2 weeks ago and she's 100% complete just want fire now
Old 08-21-2013, 10:37 PM   #7 (permalink)
Member #31787
Liked: 245 times
You might try cutting some of the insulation away from the spark plug wire and try it against the fin again. If the plug cap came off that easy, you may have just found your problem.
Then replace the plug cap with this:
NON RESISTOR SPARK PLUG CAP (B_CAP)
The shop manual for my Foreman 500 has an extensive section on coil and ignition testing, voltages, where and what to test, what equipment to use. I am certain the shop manual for your 300 will be equally helpful but I am running out of ideas from here.
Rick
Old 08-22-2013, 05:18 PM   #8 (permalink)
Member #4444
Well guys I took a coil and a cdi off a running bike and no fire even took the plug out and layed it to the fin agin and still no fire could this be a wiring harness problem
Old 08-22-2013, 05:48 PM   #9 (permalink)
woody_d87's Avatar
Member #32983
View woody_d87's Photo Gallery(0)
What else have you checked? I'm looking in the book here and it says there's a main fuse that would cause it not to get spark under the seat. It's also telling me about a test to see if you are getting voltage to the ignition control module. It says disconnect the connectors, turn on your ignition switch, and engine stop in the run position. Then connect your positive multimeter lead to the black/white connector pin and the negative to the green/white pin. It should read what battery voltage you have. After that, you have the pulse generator resistance test, reverse switch test (won't allow it to start if faulty), and then the stator resistance test.
woody_d87 is offline   Reply With Quote
Old 08-22-2013, 05:49 PM   #10 (permalink)
woody_d87's Avatar
Member #32983
That was for a TRX300EX. Hope that's the bike you are talking about.
1994 honda atv coil and plug wire problems
2006 honda foreman ignition coil
coil trx450 s
honda 300 coil
honda 300 coil test
honda 300 test coil
honda fourtrax 300 ignition coil
how do i use a 1 prong coil for honda atv
how to test a coil on a 300 ex
how to test a honda atv coil
how to test pickup coil on honda atv
testing a honda fourtrax 300 coil
