1987 250X Carburetor Problems? - Honda ATV Forum
Old 04-14-2010, 10:26 AM   #1 (permalink)
rmdohen's Avatar
Member #2820
View rmdohen's Photo Gallery(0)
Hello everybody.
I recently purchased a 1987 Honda 250X FourTrax. It had been sitting for a year or two before I bought it and thus would not idle properly, so I cleaned and rebuilt the carburetor. Now, it stays running at idle but has these problems:
1. the RPMs vary up and down more than I feel that they should
2. it backfires out the exhaust quite a bit (it did that before the rebuilt as well)
3. the throttle response is a bit hesitant if it is accelerated hard from idle
4. the exhause head pipe glows orange/red sometimes
I have done a bunch of maintenance, all to no avail:
1. adjusted valve clearance
2. cleaned/oiled air filter
3. adjusted carb pilot jet screw (does not seem to make much of a difference in the run quality) and idle screw
4. adjusted throttle cable
5. new gasoline
6. new fuel filters/fuel line
It seems that it must be running lean (at least at times) because of the head pipe getting hot enough to glow.
So, is it possible that the carb is wore out and not responding to the adjustments or quick throttle inputs and I need a new one?
If so, what are the differences between the carbs for the different year 250Xs and the 300EXs? The repair manual I have states different pilot jet screw settings for the different year carburetors, which leads me to believe that there are some differences between some of the carburetors.
Or does anybody have any other suggestions or things to try?
Thank you for any help.
rmdohen is offline   Reply With Quote
Old 04-14-2010, 11:10 AM   #2 (permalink)
Member #417
Liked: 300 times
Welcome to the forums.
if my memory serves me the 250x carb is jetted at 35 slow and 122 main the 300ex is 38 slow ans 128 main but they are the same carbs. if you have aftermarket exhaust and filtration you will need to step up the jets I suggest 130 main and 40 slow. then turn the pilot screw in until it seats and back it out 3 turns and reset the idle. that should solve the lean issue. the backfiring is due to the slow jet being too small or you have a leaking O-ring on the intake boot. the glowing pipe is in fact a lean condition. but if you are above 5000 ft elevation you need to drop down to a 118 jet on the 250 carb and turn the pilot in 1/2 turn. If the airbox lid is off put it back on and try it. Also make sure your choke is all the way OFF (in the down position)
NOTE: In the winter the air is more dense so uping the jets is a must. it's better to be a little rich than to run lean. That will melt a piston.
Old 04-14-2010, 03:16 PM   #3 (permalink)
Billy250X's Avatar
Member #1088
View Billy250X's Photo Gallery(0)
If the head pipe glows it is lean.Go up on your main and pilot jetts.Stock are 38 pilot and 122 main.
Billy
1991 Trx250X Custom exhaust,K&N jetted,widened 7.5 inches in the back and 8 inches in the frontWarrior rear shock and z400 front shocks with custom brackets.Race cut fenders.+3 swingarm.Way more to come.
Building things makes me happy.
Billy250X is offline   Reply With Quote
Old 04-14-2010, 04:01 PM   #4 (permalink)
rmdohen's Avatar
Member #2820
Thanks for the replies/advice.
TRX2fiveO:
The bike is completely stock (as far as I know/can tell) and when I rebuilt the carburetor I replaced the jets with the stock size, which was what also was already in there.
I will try to reset the pilot jet screw at three turns out from fully seated and see if that helps.
If not, I will take it apart and take a look at the intake boot and the o-ring between it and the engine.
I am not located in high altitudes, do not run it with the airbox lid removed, and have been operating the choke properly.
Billy250X:
Being that the bike is stock, I should not have to increase the jet sizes, right?
Old 04-14-2010, 04:20 PM   #5 (permalink)
If the ATV is stock, then stock size jets should be fine. Just make sure the jets in your carb ARE the stock size. Someone could have changed them before you got the ATV. You may still have some debris in your carb. Sometimes it's easy to miss something. The fact that it had been sitting for a year or two makes me think the carb is the problem, but I could be wrong.
Old 04-14-2010, 04:41 PM   #6 (permalink)
rmdohen's Avatar
Member #2820
Yeah, I may end up having to tear back into the carb to re-clean it and to double check the jet sizes. I did put in the stock size listed in the service manual, but maybe I screwed up somehow.
Old 04-14-2010, 07:13 PM   #7 (permalink)
Member #417
Liked: 300 times
the 87 had a 122 main and 35 slow it wasn't until the 90s they upped the jet sizes to what the 300exs are . 122 and 38 stock setting on the pilot for a non modifyied engine is 2 1/2 turns out from seat. I woould set it there and then turn it in 1/4 and reset the Idle
Old 04-15-2010, 09:43 AM   #8 (permalink)
rmdohen's Avatar
Member #2820
I took it out riding last night. I tried the pilot screw at 2 1/2, 3, and 3 1/2 turns out from the fully seated position. It did not matter, the head pipe would still glow at all settings. Also, the idle raised up as I was riding it and I kept having to try to adjust that back down.
Old 04-15-2010, 09:46 AM   #9 (permalink)
Fastas's Avatar
Member #897
View Fastas's Photo Gallery(0)
i have to do the same to mine now guys mine is runnign very lean exhaust got very hot the other day, so im sure ill be getting yall to give me the specs on jets and everything soon when i get rdy to do it.
www.themudwarriors.com
Fastas is offline   Reply With Quote
Old 04-15-2010, 12:12 PM   #10 (permalink)
Member #417
Liked: 300 times
Pull the carb and remove the bowl. Pull the jets out and let us know what jet sizes are in it. we can make a better diagnosis as to what you need to be running from your reply. also while you have it out go ahead and give it a good cleaning again. there are very tiny orfices in these carbs and even the most minute piece of trash will screw with you head enormously. But if I had to guess I would be running a 40 slow jet and a 130 main.
1987 honda 250x carb adjustment
1987 honda 250x carburetor needle jet
1987 honda 250x carburetor needle size
1987 honda trx250x backfire at high speeds
1987 honda trx250x carburetor
1987 honda trx250x carburetor adjustment
1987 honda trx250x exhaust glows red and backfires
81986 250x carburetor spec
87 honda 250 carb settings
87 trx250x carb adjustment
88 honda fourtrax 250x how to adajustcarburetor
