clutch slipping - Honda ATV Forum
Old 01-20-2013, 05:03 PM   #1 (permalink)
ltec's Avatar
Member #21908
View ltec's Photo Gallery(0)
clutch slipping
1999 honda trx 300.
the clutch is slipping and has been from i got it, its properly adjusted.
do i change the oil first
oil and filter
just the friction plates or
full clutch kit?
When its stripped down how can i tell if it needs more than the plates?
I dont want to throw money away but at the sametime i want her right
ltec is offline   Reply With Quote
Old 01-20-2013, 06:24 PM   #2 (permalink)
Turkey's Avatar
Member #28020
View Turkey's Photo Gallery(0)
The best thing to do is buy the full clutch kit and replace everything so you don't have to work on it again.
Turkey is offline   Reply With Quote
Old 01-21-2013, 08:26 PM   #3 (permalink)
dave4881's Avatar
Member #96
View dave4881's Photo Gallery(0)
Originally Posted by ltec View Post
1999 honda trx 300.
oil and filter
full clutch kit?
I bought a used 05 TRX400ER and the clutch slipped on it too. I changed the oil a couple of times, each after riding it for about an hour. That took care of my problem. You might give it a try.
Be sure you DONT use oil that has "Enegy Conserving" on the label.
Dave
Two 05 TRX400EX
06 450R
03 GL1800
dave4881 is offline   Reply With Quote
Old 01-22-2013, 04:02 AM   #4 (permalink)
crankestein's Avatar
Member #20918
View crankestein's Photo Gallery(0)
Clutch kits are not that expensive, and it can be done in a few hours easy. Make sure to dip the discs on oil for an hour before install.
crankestein is offline   Reply With Quote
Old 01-23-2013, 02:02 AM   #5 (permalink)
Liked: 52 times
Get both the friction plates,and the steels(look for dimpled type,much better holding power along with longer lasting) along with new clutch springs,soak the fibers overnight in the proper 4 stroke oil,and make certain you ONLY RUN 4 stroke,wet clutch safe oil NEVER automotive type oil in it...A new right outer case cover gasket,and you should be fine unless you wish to change the timing chain,one way bearing,and oil pump rotors while you're that far in it in which case order those parts as well,and do them all at the same time,most likely never have to go back into that side of the engine again ever if maintained properly after wards...
Old 01-25-2013, 09:22 AM   #6 (permalink)
Crockett's Avatar
Member #28006
View Crockett's Photo Gallery(0)
I had a similar problem where I had acquired a 250x that has been sitting for years. After building the clutch, it fired up just fine and I drove it around without a problem. Then I changed the oil with the proper wet clutch oil and the clutch stopped working altogether. Bought a new clutch kit for about $60, and about an hour in the garage I had it installed. Everything runs good now. I would replace the clutch with a new clutch kit.
Crockett is offline   Reply With Quote
atv clutch slipping
atv clutch slipping engine oil
changed oil in my atv now slipping
fourtrax 300 clutch slipping
fourtrax 300 new clutch springs now slipping
honda atv clutch problems
honda atv clutch slips after oil change
honda atv new clutch slipping
honda trx 700 clutch kits
honda trx change clutch slips
how to slip a atv clutch
slipping atv clutch what parts do i need to buy
