Originally Posted by iceman320
thanks for the help guys i'm looking at some nerf bars right now. so I will either buy a set or make me a set of them out of some square tubing. as for the fuel controller i probably won't be doing any mods to the exhaust or engine until I get use to the power of the 700xx. cause i'm guessing the 700 is going to pull 10x harder than my 250ex ever did so it will take some getting use to the new power and the new clutch. so i will probably hold off on performance mods for a little bit. also is there a set of good nerf bars for the 700 that are under 200 bucks that would be good? thanks so much for your help.
Yeah, you will have much, much, more power with the 700. You'll probably be happy with it without any mods, for a while, anyway.
By the way, in addition to what Red said, those nerf bars will help keep you from getting the tires hung together with other ATVs or climbing over other tires if you ride with someone, side by side. That can be dangerous.
