Sea foam - Honda ATV Forum
post #1 of 7 (permalink) Old 05-28-2012, 10:35 PM Thread Starter
normrivard's Avatar
Sea foam
Hi, which seam foam you people use for your quad ? For what i can see there is 2 types one that you spray in the carb or the one you can put in your gaz tank and your motor oil.
Which one do you recommend
in friendship
norm
normrivard is offline
post #2 of 7 (permalink) Old 05-28-2012, 11:47 PM
jkhuntin's Avatar
Liked: 19 times
I use the pour in kind. I put it in the 5 gallon gas can that I use to fill up the quad.
2004 Rincon
2" lift
27" mudlites, ITP SS212's
Mud bike
2013 Rancher 420 AT.
jkhuntin is offline
post #3 of 7 (permalink) Old 05-29-2012, 04:19 AM
sampey22's Avatar
agree with the kind goes in your gas the one u spray isnt worth a crap
sampey22 is offline
post #4 of 7 (permalink) Old 05-29-2012, 06:43 AM
Dan G's Avatar
Liked: 6 times
x2 the kind that goes in the gas... If you are using it to remove carbon from the head either find a vacuum line if applicable or put it into a spray bottle, hold the throttle open a bit and spray like mad, spray a lot into there, and when the engine wants to die out shut it off. Let it sit 5-10 min, fire it up and go for a ride, beat on it a little bit until it stops smoking white stuff.
Dan G is offline
post #5 of 7 (permalink) Old 05-29-2012, 08:30 AM Thread Starter
normrivard's Avatar
Thank you guys Ill do that today
TRX300 2X4 1994
post #6 of 7 (permalink) Old 05-31-2012, 06:43 AM
gottaroost's Avatar
Sea Foam is great stuff but remember, More is NOT Better!! I bought a Yam Warrior off a guy awhile back who had put an entire can of SF in his gas tank...he said it ran great for a few minutes then went boom.
What it caused by putting too much SF was a massive thinning out of top end lubrication. So for him it made the exhaust valve freeze up which resulted in needing a new head and piston.
2008 Raptor 700SE
2002 400EX
2010 Raptor 250
2008 Raptor 250
gottaroost is offline
post #7 of 7 (permalink) Old 05-31-2012, 07:30 AM
Dan G's Avatar
Liked: 6 times
x2! When I say use a lot, only when your spraying it into the intake to clean the carbon from the piston and valves. If your using it in the fuel system, no more than 3-4 oz per gallon. 2oz to maintain per gallon afterwards.
Dan G is offline
