87 250x wont start - Honda ATV Forum
Old 05-15-2012, 02:54 AM   #1 (permalink)
frost's Avatar
Member #18692
View frost's Photo Gallery(0)
87 250x wont start
i have a 87 honda 250x i just got the 4 wheeler this past Saturday rode it around a little had to put a new bolt in the flange on the header pipe cause it was messing one and causing it to back fire when shifting. well i have a problem now it wont start it died out on me coming down the rode and wouldnt start back. i flushed the gas tank out cause there was a little rust in it, and if the petcock is left in the on position gas starts leaking out of the overflow tubes on the carb. i checked the spark plug its firing nice and blue like its suppose to. could the carb. be clogged and cause it not to start? i tried starting it sunday evening and the only thing it did was backfire once and nothing else? and could someone be able to tell me what kind of exhaust is on it please ? thanks in advance for the help
frost is offline   Reply With Quote
Old 05-15-2012, 11:44 PM   #2 (permalink)
Welcome to the forums. I would start by cleaning the carb. The float needle is sticking open, that's why the gas is running out the overflow hose on the bottom of the carb bowl. Since the gas tank had rust in it, more than likely, there's pieces of rust in the carb. You might want to install an inline fuel filter to keep rust out of the carb.
Old 05-16-2012, 01:56 AM   #3 (permalink)
frost's Avatar
Member #18692
ok thanks for the info im going to be but a rebuild kit for the carb this weekend and clean it up im hoping that fixes my problem. any idea on what kind of exhaust that might be ?
Old 05-16-2012, 02:03 AM   #4 (permalink)
The exhaust looks like a Cobra.
Old 05-16-2012, 07:20 AM   #5 (permalink)
Member #417
Liked: 286 times
Agree^^^^ welcome to the forums
Old 05-16-2012, 09:15 AM   #6 (permalink)
300ExBoyz's Avatar
Member #18205
View 300ExBoyz's Photo Gallery(0)
Thats a nice looking 4 wheeler to be 25 years old all it really needs is a seat and maybe a paint job on the engine.Id try cleaning out the gas tank and cleaning the gas tank valves.I have found some nasty stuff in mine before and then go a head and work on the carb if your gas tank valves are dirty then id clean the carb also.
300ExBoyz is offline   Reply With Quote
Old 05-16-2012, 09:31 AM   #7 (permalink)
Member #417
Liked: 286 times
Make sure the decompression system is properly adjusted. This too will create a hard start.
Old 05-16-2012, 01:03 PM   #8 (permalink)
frost's Avatar
Member #18692
thanks for the info guys i plan on working on it this weekend ill let you all know if i get it back to running
Old 05-16-2012, 08:49 PM   #9 (permalink)
jkhuntin's Avatar
Member #4493
Liked: 16 times
Welcome from the Volunteer state.
2004 Rincon
2" lift
27" mudlites, ITP SS212's
Mud bike
2013 Rancher 420 AT.
Old 05-16-2012, 11:48 PM   #10 (permalink)
Liked: 52 times
Welcome to da forums... Agree on the carb,petcock,fuel line,and tank all need to be thoroughly cleaned out,inline fuel filter installed,looks like a stock headpipe with an aftermarket slip on muffler...
1991 honda 250x wont start
250x wont start
87 250 trx wont start
87 honda 250 x paibted frame now wont start
87 honda 250x
87 honda 250x quad will not start
87 honda 250x wont start
87 trx 250x shifting
91 trx 250x backfires but wont start
honda 250x wont run properly
how to clean a carburetr on a honda 250x
