07 400ex Re-jetting questions - Honda ATV Forum
post #1 of 11 (permalink) Old 04-17-2012, 05:17 PM Thread Starter
banditalex's Avatar
Hi all, long time no see. I just ordered a new exhaust slip on(hmf), jet kit, and kn air filter. My question is, how hard is it to rejet a 400ex?I believe I can install the pipe my self, but I am worried about doing the jetting, I'm just afraid to mess something up as the bike runs fine right now. Thanks for the help!!!
Alex
banditalex is offline
post #2 of 11 (permalink) Old 04-17-2012, 07:38 PM
all4honda's Avatar
The jets are very easy to change once you get carb off. If your unsure where they go, look at the service manual
all4honda is offline
post #3 of 11 (permalink) Old 04-17-2012, 07:43 PM
slincolnn's Avatar
You actually don't have to pull the carb all of the way off.You can loosen the carb boots and turn it sideways to access the bowl.Remove the hex plug in the bowl and the main jet is right there.
07 Foreman 500
04 250ex
06 yamaha Wolverine 450
03 recon
slincolnn is offline
post #4 of 11 (permalink) Old 04-17-2012, 09:45 PM Thread Starter
banditalex's Avatar
so it is pretty easy eh? anyone have pics or illustrations of the jets ( i have no clue what they look like) lol
post #5 of 11 (permalink) Old 04-17-2012, 11:24 PM
The main jet is the only jet that you can change through the hole in the bottom of the bowl, but the main jet is only one you need to change anyway.
post #6 of 11 (permalink) Old 04-18-2012, 10:39 PM Thread Starter
banditalex's Avatar
thank you very much, i only need to change that one jet eh?
post #7 of 11 (permalink) Old 04-18-2012, 11:44 PM
Yeah, generally, when jetting for the addition of a pipe and filter, all you need to change is the main jet. And you're welcome.
post #8 of 11 (permalink) Old 04-19-2012, 06:16 AM
DAN400ex's Avatar
Hear is a link that will help you get to the picture Helmut posted... Its technically for a pilot jet but the main and pilot jets are right next to each other...
Honda 400EX ATV Pilot Jet Insturctions - ATV Technical Articles
2008 TRX400ex
42 pilot jet
Stage 2 Dynojet kit
K&N Powerlid
Lexx MXe slip on
450r front suspension
Dan in VA
DAN400ex is offline
post #9 of 11 (permalink) Old 04-19-2012, 01:44 PM Thread Starter
banditalex's Avatar
Thanks Dan, I appreciate it!!! When they come in I'll let ya'll know how it went
post #10 of 11 (permalink) Old 04-20-2012, 05:40 PM
whyzee's Avatar
You don't even have to loosen the boots and twist the Carb.
just flip up your choke lever, disconnect the oil breather tube , cover with the paper towel in case you accidentally drop your jet it won't fall into it.
18mm wrench, take off Carb drain bowl, insert 4.5 mm socket into Carb and get it on the main jet and remove.
When reinstalling, do not over tighten the jet or Carb bowl, they will strip very easily
whyzee is offline
