Old 02-09-2012, 10:57 PM   #1 (permalink)
2012honda's Avatar
Member #15955
View 2012honda's Photo Gallery(0)
Slip on info
Well a slip on hmf help out with performance any? I do not feel like getting the whole system and getting the quad re jetted cause I know that's what your supposed to do if you get the full system. Again well a hmf slip on help a trx400 out performance wise? And if I were to get the full system and not get it re jetted what would happen?
2012honda is offline   Reply With Quote
Old 02-09-2012, 11:02 PM   #2 (permalink)
Member #7607
View Manny's Photo Gallery(0)
i strongly recommend rejetting after you install the slip on. regardless if you go with the full exhaust or not. you will be running lean if you dont. add a uni or k&n air filter to that and you will notice a significant increase in power.
2001 Rubicon 500 5k+ miles 1100+hours
26 Inch Mudlite XL's, G Force Slammer wheels, Superwinch Terra
Realtree AP Plastics
Warn 2000 Lb. winch
Sedona Ripsaw tires
Fourtrax 300 Parts for sale CLICK HERE
The truth about ATV oil:
http://www.dirtrider.net/forums3/tex.../146867-1.html
Old 02-09-2012, 11:20 PM   #3 (permalink)
2012honda's Avatar
Member #15955
Is it bad to run it lean with just the slip on?
Old 02-10-2012, 01:40 AM   #4 (permalink)
Member #7607
Yes, its bad to run an engine lean period. your more prone to overheating and detonation leading to engine damage over time.
Warn 2000 Lb. winch
Sedona Ripsaw tires
Old 02-10-2012, 02:04 AM   #5 (permalink)
jkhuntin's Avatar
Member #4493
Any time you increase airflow( which you will be doin even with a slip on ) you need to rejet. Engines tend to run better lean, just not as long. Increased airflow = lean, lean = increased heat, increased heat = meltdown. And welcome from the Volunteer state.
2004 Rincon, 2" lift, 27" mudlites, ITP SS212's, 710 BBK and hot cams mudbuster.
jkhuntin is online now   Reply With Quote
Old 02-10-2012, 07:05 AM   #6 (permalink)
mdec950's Avatar
Member #13751
View mdec950's Photo Gallery(0)
Welcome to the FORUMS
2001 TRX250 Recon
2002 TRX400 EX
2004 TRX400 Rancher GPS
If you can't figure it out,
rule 1 - drink a beer,
rule 2 - see rule 1 - rinse and repeat
rule 3 - calm down and let it sit - leave it alone
rule 4 - get on here and ask Helmut or Shadetree
rule 5 - and be nice when you ask.
rule 6 - go and
mdec950 is offline   Reply With Quote
Old 02-10-2012, 07:18 AM   #7 (permalink)
Alfresco's Avatar
Member #11638
View Alfresco's Photo Gallery(0)
I suggest that if you don't want to re-jet, then just leave the exhaust alone.
2000 400EX
Alfresco is offline   Reply With Quote
Old 02-10-2012, 01:10 PM   #8 (permalink)
2012honda's Avatar
Member #15955
I'm gonna reject now I didn't think a slip on without a re jet would be that big of a problem. thanks a lot everyone. Any tips on what jet kit I should get size and all that good stuff, it's for a 2012 trx400x quad hmf slip on.
Old 02-10-2012, 01:56 PM   #9 (permalink)
Member #7607
i use dynojet. although HMF, MOOSE, and others...ebay is your friend.....when you go to purchase the jet kit, buy a stage 1.
Warn 2000 Lb. winch
Sedona Ripsaw tires
95 honda foreman 400 overheating why?
do you need to jet atv for a slip on
foreman 400 dynojet jet size
honda atv 500 foreman 2002 jet size
honda foreman 400 slip on jet kit
how to instal a 2001 honda rubicon hmf
increase power on a fourtrax 300
re-jetting 2001 honda rubicon
should i jett quad with slip on
what jet kit to install in honda foreman 400 in texas
what size jet kit for 2001 honda rubicon
what size jet should u use on honda 500 with hmf
what size jets should i use with a slip on
