Valve adjustment - Honda ATV Forum
post #1 of 12 (permalink) Old 02-01-2012, 06:20 PM Thread Starter
KTM250EXC250's Avatar
Valve adjustment
In the service manual it says "turn the adjustment screw until there is a slight drag felt on the feeler gauge" ..What's a slight drag!?!? I think my last adjustment i probably tightened it too much. But are you supposed to be able to slide the gauge freely and when it doesnt slide freely then they're adjusted properly? I just need a little better of an explanation on this..
Thanks a lot
-Will
2002 400ex
-K&N
-Yoshi Full Exhaust
-450r Timing chain
-Namura 11:1 Piston
KTM250EXC250 is offline
post #2 of 12 (permalink) Old 02-01-2012, 06:26 PM
Tighten it down on your feeler gauge until you can feel the drag on it when you pull it out. In other words, it should be a snug fit.
post #3 of 12 (permalink) Old 02-01-2012, 08:49 PM
rich250rracer's Avatar
Liked: 14 times
I like to coat the feeler guage with a little bit of oil, and tighten until you just start to feel resistance while pulling it out. If you're dealing with small clearances, .002-.004, you should feel the resistance while pulling it out and the feeler guage should try to buckle slightly if you push it back in.
2014 CRA Senior II and Buckeye Series champ
2012 CRA Senior II champ
2011 CRA Senior II and Buckeye series Harescramble Champion
2009 CRA Senior II and Buckeye series champ.
2007 CRA Senior II, and Buckeye series Harescramble Champ.
2007 TRX450R
2005 TRX450R
2004 TRX450R
2003 Lonestar 250R
1999 CR500
1999 CR250
1996 CR250
1986 ATC250R
1975 MR50
1999 Banshee
rich250rracer is offline
post #4 of 12 (permalink) Old 02-01-2012, 09:29 PM
Liked: 316 times
Agree^^^^ just like I said in another thread I set them on the tight side of the feeler (snug fit)
TRX2fiveO is offline
post #5 of 12 (permalink) Old 02-02-2012, 12:51 PM Thread Starter
Me too. So having them tighter is better than loose (which is pretty hard to set them to unless you try...)
2002 400ex
-K&N
-Yoshi Full Exhaust
-450r Timing chain
-Namura 11:1 Piston
post #6 of 12 (permalink) Old 02-05-2012, 02:29 PM
bamaboy1285's Avatar
valves clicking?
My valves are clicking does that mean that they need to be adjusted?
bamaboy1285 is offline
post #7 of 12 (permalink) Old 02-05-2012, 05:39 PM
Either they need to be adjusted or your cam and/or rocker arms are worn. Try adjusting them first.
post #8 of 12 (permalink) Old 02-05-2012, 07:24 PM
Thanks. Do you know if there are any "how to" videos. I have a general idea, im just not 100% sure.
post #9 of 12 (permalink) Old 02-05-2012, 07:33 PM
Atieri's Avatar
get a service manual for pete's sake, then if you still don't get it, you're in trouble
Atieri is offline
post #10 of 12 (permalink) Old 02-05-2012, 07:33 PM
Liked: 316 times
What are we working on??
