Old 01-21-2012, 05:25 PM   #1 (permalink)
poult's Avatar
Member #6735
View poult's Photo Gallery(0)
2006 680 rincon over heating problem
[I] have a buddy that bought a used rincon 680 and he drove it today, and it overheated. The fan ran sometimes, but not sure if it ran enough?
Does anyone have any ideas?
Thanks,
Bill
poult is offline   Reply With Quote
Old 01-21-2012, 05:30 PM   #2 (permalink)
Welcome to the forums. Make sure your radiator fins are not clogged with mud, particularly the rear of the radiator where it's hard to see and hard to clean. I don't have any experience with the Rincon, but I've heard a lot guys talking about the radiators getting clogged up with mud and not getting the proper air flow through the radiator, causing it to run hot.
Old 01-21-2012, 05:38 PM   #3 (permalink)
See this thread:
another rincon heat problem :)
Old 01-21-2012, 05:50 PM   #4 (permalink)
Ballast's Avatar
Member #8124
View Ballast's Photo Gallery(0)
You can't properly wash the part of the rad that sits behind the oil cooler, this will be clogged with mud even when you think it has been washed. He need to remove some plastics to expose the rad then install some spacers to get the oil cooler to sit 1/2" or so ahead of the rad.
1st picture you can see mud behind the cooler blocking what I thought was a clean rad.
2006 680 rincon over heating problem-dinner-021.jpg   2006 680 rincon over heating problem-dinner-026.jpg
4 HONDAS 4 ME
07 Rincon... 26" Mud Bug Rs, 1 1/2" rear spacers, 2500# Warn winch, Kimpex box, Moose skid plate
07 Rancher 420.... C Series Type 5 IPTs w/26" Mud Lites, Moose skid plates & A-arm guards, Viper winch, Kimpex seat, fender guards
06 TRX250EX.....Tusk nerf bars, White Brothers skid plate, AC Racing swing arm skid plate, Cobra A-arm guards
85 TRX125.... 1 7/8" trailer ball
Ballast is offline   Reply With Quote
Old 01-21-2012, 07:19 PM   #5 (permalink)
Member #7607
View Manny's Photo Gallery(0)
ballast has you covered. very common problem with the rincons if you ride in very dusty/muddy conditions
2001 Rubicon 500 5k+ miles 1100+hours
26 Inch Mudlite XL's, G Force Slammer wheels, Superwinch Terra
Realtree AP Plastics
Warn 2000 Lb. winch
Sedona Ripsaw tires
Fourtrax 300 Parts for sale CLICK HERE
The truth about ATV oil:
http://www.dirtrider.net/forums3/tex.../146867-1.html
Manny is online now   Reply With Quote
Old 01-22-2012, 08:45 AM   #6 (permalink)
Ballast's Avatar
Member #8124
Yeah - no overheating problems all last season since spacing the oil cooler. Still wash it out dilegently after each mud adventure. Had to buy longer bolts to secure to the rad once the cooler was moved out. I put lots of no sieze on the steel blots to get away from the aluminum/steel corrosion issue. I also believe switching to synthetic oil helps the engines run a little cooler and if you do get real hot the synthetic doesn't break down as quickly.
4 HONDAS 4 ME
Old 02-11-2012, 12:47 AM   #7 (permalink)
moosey's Avatar
Member #16049
View moosey's Photo Gallery(0)
Spacer will solve your problem
I have to agree, once a spacer between the rad and the oil cooler is placed the has been no more overheating issues, from the factory the oilcooler is too close to the rad which also makes it very hard to clean.
Its a relatively easy job at a very low cost
Moose
2007 rincon
moosey is offline   Reply With Quote
Old 02-12-2012, 10:35 AM   #8 (permalink)
tdi
tdi's Avatar
Member #15444
View tdi's Photo Gallery(0)
Yeah the riney im working on must have had an issue because the owner installed a toggle switch to the fan.
tdi is offline   Reply With Quote
2006 rincon over heating
2011 honda rencon 680 radiator
680 honda rincon problems
680 rincon
680 rincon problems
atv overheating problem
honda 4 wheeler oil guard
honda 4 wheeler wont run when weather is hot
honda 680 oil
honda 680 overheats
honda 680 rincon cooling fan
honda atv overheating
honda rincon 680 2006
honda rincon 680 oil cooler space
honda rincon overheating
honda rincon overheating problems
rincon 680 radiator location
rincon overheating
rincon problems
