Old 09-20-2011, 09:20 PM   #1 (permalink)
5.4 speedster's Avatar
Member #4632
View 5.4 speedster's Photo Gallery(0)
How much engine oil for trx450r?
Just changing the oil for the first time and I filled it up to the mark as usual per hondas. It took a little bit less than half a quart to get it there... Is that right? I let the oil drain for 30 minutes or so although I didn't blow the old stuff out with a hose. I thought it was supposed to take just under a quart?
doberman puppieshttp://blitzkriegkennel.com/
Dobermans with Distinction
5.4 speedster is offline   Reply With Quote
Old 09-20-2011, 09:26 PM   #2 (permalink)
With filter change, the '04 and '05 take 0.87 quarts. After '05 takes 0.73 quarts. The engine oil is separate from the transmission oil on the 450R and that's why it takes such a small amount. For the transmission oil, the '04 and '05 takes 0.58 quarts and after '05 takes 0.72 quarts.
Old 09-21-2011, 03:33 AM   #3 (permalink)
Member #4632
yeah thats about the amount the tranny took. But I changed the filter on it when I did the oil and it took less than half a quart to get it to the fill line on the window
its a 06
Old 09-21-2011, 05:24 AM   #4 (permalink)
Redracer's Avatar
Member #618
View Redracer's Photo Gallery(0)
Did you put the filter in the correct way? Turn the motor over a few times to circulate the oil.
Dynamic Graphics, Inc.
Aurora Honda
LoneStar Racing
Leatt
Fox Shox
HondaATVForums.NET
Redracer is offline   Reply With Quote
Old 09-21-2011, 01:27 PM   #5 (permalink)
Member #4632
^bingo. turned it over once and added a bit more
Old 09-21-2011, 03:26 PM   #6 (permalink)
69quadracer's Avatar
Member #805
View 69quadracer's Photo Gallery(0)
Make sure the filter is in the right way or you will cook the motor!!
69quadracer is offline   Reply With Quote
Old 09-21-2011, 04:13 PM   #7 (permalink)
Member #4632
filter is properly installed.
honda 450r adding engine oil
honda 450r oil change
how many quarts of oil does a honda 450r take
how many quarts of oil does a trx 450r take
how much oil does a honda 450r take
how much oil does a honda trx 450r take
how much oil does a trx 450r hold
how much oil does a trx450r take
oil change trx450r
trx450r how much oil
trx450r oil capacity
trx450r oil change
