09-19-2011, 12:14 PM
#1 (permalink)
Member #13052
2002 trx450es shift indicator# flashing
my 2002 trx450es gear indicator# flashes and won't shift until power is turned off and on. Only happens sometimes, usually 4th &5th gear at high rpm's. Anyone have any solution?
09-19-2011, 01:36 PM
#2 (permalink)
Welcome to the forums. When you turn the key off and back on, does the gear position indicator flash? If so, count the number of flashes as this is a trouble code.
09-20-2011, 05:08 AM
#3 (permalink)
Member #13052
2002 trx450es gear indicator flashing
I don't think so, but will look for that when it happens again. I just bring the bike to a stop and turn off the key. Then I turn it on and shift it down to neutral and restart. Thanks!
09-20-2011, 04:54 PM
#4 (permalink)
Yeah, when you turn the key off and back on, that resets the ECU. The way you're describing the problem, it sounds like you may have a bad angle sensor. The angle sensor is the most common problem with the ES models. If you don't have a service manual, you can go to the manuals/schematics section of the forums and download one and it will show you how to test the angle sensor, as well as the other components of the ES system.
09-21-2011, 06:08 PM
#5 (permalink)
Member #13052
Thanks, I will look into your suggestion and let you know what I find.
09-21-2011, 06:12 PM
#6 (permalink)
You're welcome.
12-22-2011, 08:04 PM
#7 (permalink)
Member #14913
was it the angle sensor? I am having a problem like this on a 2006 TRX 350 FE rancher. When driving in 5th gear for a while the 5 starts flahing (12 times) and it will not shift. Have to turn the key off then on and can shift agin. It does not start flashing again until driving in 5th gear again. This happens every time.
12-22-2011, 08:48 PM
#8 (permalink)
Welcome to the forums. Code 12 is the gear position switch. But before replacing it, download the service manual and test the switch. You can download the service manual from the link below.
Service Manual Downloads - All years
12-22-2011, 08:49 PM
#9 (permalink)
If it asks for a password to download, the password is hondaatvforums.net.
2002 honda foreman 450 es wont shift neutral light continuously flashes, 2002 honda trx 450es shifting problems, 2002 trx450es, honda atv gear shift light blinking, honda atv shift indicator flashing, honda foreman 450 gear shift is flashing 12 times, honda trx 450 codes 6 flashes, honda trx450 es angle sensor, how ro reset trx450es code, trx 450 es codes, trx es shift indicator, trx450es shifting problems
