Cam Chain Tensioner Fix - Honda ATV Forum
Old 09-11-2011, 12:31 AM   #1 (permalink)
gottaroost's Avatar
Member #9456
View gottaroost's Photo Gallery(0)
I recently brought home a 2003 400EX and bought it cheap because it sounded like it was gonna splode. I posted here the other day about it and got confirmation to check valves and cam chain tensioner.
After setting the valves to spec, I fired it up and it was still bad sounding. I loosened the pipe and silencer so I could get to the tensioner and pulled it out. There was no spring action to it and it was completely collapsed. Not knowing how it really works, I put it back in and turned the screw to push the tensioner rod out. Then tried it again and it still sounded bad.
Took it off and realized it was missing the spring action needed to twist itself out and apply pressure to the chain guides. I tried looking up how to rebuild it and could not find any info. I decided to have a look inside. First I popped off that tiny retaining circlip and carefully pulled out the plunger assy. Mine had quit working because the tensioner spring winding had snapped at slot in the bottom of the plunger. This kind of spring is similar to what you would find in a lawnmower pull start. I pulled the rest of the wound spring assy out and using needlenose pliers reformed a new end to slide into the plunger assy.
It got kinda tricky trying to put it all back together. I coiled up the spring really tight and once it had a very small diameter, then grabbed it with the needlenose pliers and pushed it down to the very bottom of the housing. I then pushed the slotted end of the plunger assy down into the housing so it slipped over that reformed end of the spring...make sure it gets into the plunger assy slot or it will not work.
You do not need to preload the spring at all, it is pretty much impossible due to the direction the plunger assy unscrews anyway. So I set it in there and wiggled it around back and forth a bit until it all fit down in there. Then the hardest part was holding it all together and putting that little circlip back on. A second pair of hands would be nice but not necessary.
I decided to give this a try because I went on ebay earlier and everyone wants $50+ for a new tensioner and I would have to wait a week to get it. Anyway, it worked and now this EX is no longer a ticking time bomb. I wish I could have taken pix but I did not have any help and most of the time I didn't think I was gonna come out on top of it. Anyway, it is a pretty simple fix once you tear into it and may save you some $$$ if you give it a try.
2008 Raptor 700SE
2002 400EX
2010 Raptor 250
2008 Raptor 250
gottaroost is offline   Reply With Quote
Old 09-11-2011, 01:10 AM   #2 (permalink)
Liked: 1517 times
nice post gotta..thank you for the info..maybe this can help someone else out later down the road..thank you.
Old 09-11-2011, 08:51 AM   #3 (permalink)
Member #417
Liked: 304 times
Good post the cool thing would of been to have pics too.. thanks for sharing
Old 09-11-2011, 11:52 AM   #4 (permalink)
gottaroost's Avatar
Member #9456
Oh I hear ya about not getting any pix...it was my first DIY and it was late last night...and no camera. I guess if anyone on here has a broken one laying around and wants to send it my way, I will take another shot at it and will have the camera handy this time around.
2008 Raptor 700SE
2002 400EX
2010 Raptor 250
2008 Raptor 250
Old 09-11-2011, 11:54 AM   #5 (permalink)
DiabloAmarillo's Avatar
Member #12384
View DiabloAmarillo's Photo Gallery(0)
was the noise a knocking sound or more of a rattle tap noise?
DiabloAmarillo is offline   Reply With Quote
Old 09-11-2011, 03:23 PM   #6 (permalink)
I've fixed a few tensioners on Fourtrax 300s, like that.
Old 09-11-2011, 05:01 PM   #7 (permalink)
gottaroost's Avatar
Member #9456
Rattle tap with some clanging here and there. It sounds like a normal motor now so the tensioner made all the difference for this particular EX anyway. I have another loud-as-heck EX (2006) stored offsite so I am anxious to bring it back home and see if suffers from the exact same problem. I had taken its tensioner out a few months ago but at that time did not fully understand a good one from a bad one.
Of course if it is not the tensioner, then I am gonna be bummed. The valves are in spec so that will mean some pretty deep issues in crank or bearings, rod etc.
2008 Raptor 700SE
2002 400EX
2010 Raptor 250
2008 Raptor 250
Old 09-23-2011, 04:20 PM   #8 (permalink)
Reece616's Avatar
Member #3038
View Reece616's Photo Gallery(0)
I messed around with mine today and snapped some pics to help with your description...
Cam Chain Tensioner Fix-2011-09-23_15-44-51_648.jpg   Cam Chain Tensioner Fix-2011-09-23_15-46-09_531.jpg   Cam Chain Tensioner Fix-2011-09-23_15-46-36_304.jpg   Cam Chain Tensioner Fix-2011-09-23_15-46-51_203.jpg
2006 TRX400ex
AC Nerfs - Swingarm Skid + Honda Racing Skid - Protaper Contour Bars - Rox 2" Riser - CBR Clutch Perch - Oury Grips - HT Moto Seat Cover - Custom Poly Case Saver - TRX450R Front Shocks - XR250R CDI - YFZ 450 Dual Piston Front Calipers - ITP T9 Baja Rear + GBC X-Rex - CanAm DS450 Front Rims +Holeshot SR Front - Dominator Bumper - UNI Filter - 13/39 Gearing - DID x-ring Chain
2004 TRX250EX
AC Racing Nerfs - Oury Grips - Fmf Slip-on - Uni Filter - Razr Rears
Reece616 is offline   Reply With Quote
Old 09-23-2011, 05:31 PM   #9 (permalink)
Member #417
Liked: 304 times
now can you get it back together?? lol
Old 09-23-2011, 06:41 PM   #10 (permalink)
Reece616's Avatar
Member #3038
Yea, actually. I had it back together and then realized I didn't take pics so I did it again haha
2006 TRX400ex
2004 TRX250EX
1998 honda foreman 450 es timing chain tensioner
2003 honda foreman 450 timing chain
2005 honda trx450r replacing timing chain tensioner
450 foreman timing chain noise
honda foreman 450 cam chain tensioner
honda foreman 450 timing chain replacement
honda foreman450 chain tenser
honda trx500 chain tensioner
how do i set the time chine tension on 1998 honda foreman 400
how do i set the timing on a 450 es honda
timing chain guides on a trx 99 450 esx foreman
trx500 cam cahin tensioner location
