12-02-2009, 07:28 PM
#11 (permalink)
Member #659
from what i hear you shouldnt run a k&n air filter they let more dirt pass thru.get a good foam filter!
12-02-2009, 07:34 PM
#12 (permalink)
Member #618
I agree 100%. K&N with a pre-filter is good in my book though.
I don't want to arrive at the Pearly Gates in a well preserved body... I want to slide in sideways screaming "NOW THAT WAS A F'ING RIDE"
12-02-2009, 11:19 PM
#13 (permalink)
Member #1331
so should i go UNI or K&N? why is K&N so expsensive, and UNI isn't very?
12-03-2009, 06:47 AM
#14 (permalink)
Member #618
UNI is a foam filter, and K&N is really proud of their products. I prefer a foam filter myself. No-Toil makes a great foam filter. Honda uses UNI from the factory.
12-03-2009, 12:59 PM
#15 (permalink)
Member #659
uni,twin air,stay away from k&N!
12-19-2009, 09:29 PM
#16 (permalink)
Member #1466
how can i eliminate my igmition key with toggle switches on a 2004 honda 400ex
12-19-2009, 11:08 PM
#17 (permalink)
Member #618
Take the wires that go to your key and hook them up to a toggle switch.
01-13-2010, 07:00 PM
#18 (permalink)
Member #1674
k&n is the best i have not had no probem.that is the kind of riding i do .
01-13-2010, 07:10 PM
#19 (permalink)
Member #1536
I do a lot of riding in the sand and have used k&n for 10yrs with no issues AS long as you use a pre-filter with it. K&N is so expensive cause they are reusable many yrs over just spray on they're cleaner and spray off with water then use they're filter oil and go very painless. The pre-filter actually repel water, but not if you submerse it in mud lol.
I'm just saying!
05 TRX 501
97mm bore
14.5 CP (Venom) piston
+3 stroker
Venom head porting
+1 valves
Stage 3 Hot Cam
ESR modded intake
K&N filter
Sredrum 42mm
Venom exhaust
+5 swinger
Dyna Ignition
01-14-2010, 05:24 PM
#20 (permalink)
Member #126
Agree^^^^^^^^^^^
» Site Navigation |
» Honda Forums
