1988 trx250x - Honda ATV Forum
Old 07-21-2011, 07:36 PM   #1 (permalink)
pokienoze's Avatar
Member #11756
View pokienoze's Photo Gallery(0)
1988 trx250x
I bought a TRX250X with a ticking noise in it. We open up the top end and noticed the rocker arms were worn. We replaced those, as well as, the Cam Shaft and bearings but 4-wheeler still is ticking loud. When accelerating it gets louder and faster. Any ideas?
pokienoze is offline   Reply With Quote
Old 07-21-2011, 07:54 PM   #2 (permalink)
Liked: 52 times
Welcome to the forums...Free downloadable manuals in the Schematics/Manual help section in the Technical discussions ...Did you check the timing chain,and adjuster while you had it apart??? Maybe there's an exhaust leak???
Old 07-21-2011, 08:02 PM   #3 (permalink)
Member #417
Liked: 286 times
how did you adjust the valves? when you installed the cam did you put it in lobes down? it's possible you adjusted them on exhaust stroke
Old 07-21-2011, 08:33 PM   #4 (permalink)
Old 07-22-2011, 04:01 PM   #5 (permalink)
pokienoze's Avatar
Member #11756
Valves are adjusted to spec. My brother is the one doing the work and he can't figure out why it would be tapping the way it is. No exhaust leak and the timing chain,and adjuster are good. Any other ideas on what could be causing it?
Old 07-22-2011, 04:09 PM   #6 (permalink)
Liked: 52 times
It won't hurt to adjust them again on the off chance he missed something,or did them wrong...
Old 07-22-2011, 04:10 PM   #7 (permalink)
Liked: 52 times
Does it make any popping out of the exhaust,or carb/airbox at idle,kinda quiet popping noise???
Old 07-22-2011, 04:28 PM   #8 (permalink)
pokienoze's Avatar
Member #11756
The noise comes from the engine itself. The top end. It gets louder and faster as you accelerate. At an idle the tapping is pretty quiet.
Old 07-22-2011, 05:02 PM   #9 (permalink)
Member #417
Liked: 286 times
Did you put a stock cam back in???The easiest way I can explain how to adjust the valves on a 250X is remove the spark plug, the side plugs on the stator cover take a 17mm socket and put in the larger hole rotate the engine counter clockwise until you allign the "T" mark with the notch in the little hole. Grab the exhaust rockers and wiggle them remember how loose or tight they were now rotate the engine 360 and allign the "T" again check the rockers, which ever way they were the loosest is TDC Compression stroke. make your adjustments there. a tight .004 int and exh. Make sure you do this with a cold engine. or you will get an inaccurate reading.
Old 07-22-2011, 05:16 PM   #10 (permalink)
Liked: 52 times
Would be nice if you knew whether the cam is stock,or not/what brand,and grind it is as most aftermarket cams call for different valve lashes than an oem stock cam...
1988 honda 250x specs
1988 honda trx250x
1988 honda trx250x cam timing
1988 honda trx250x specs
1988 trx 250 x
1988 trx250x
1988 trx250x specs
88 honda 250 x specs
88 honda 250x specs
cam and rocker arms for 1988 honda 250x
trx 250x ticking problems
