Clutch Slipping - Honda ATV Forum
Old 07-20-2011, 02:36 AM   #1 (permalink)
TRX200R's Avatar
Member #8936
View TRX200R's Photo Gallery(0)
Clutch Slipping
So recently my TRX 200 has lost alot of power. When i go WOT it just revs high and has no catch so i assume the the clutch is going it used to onley do it in fourth but it has moved to all other gears any info would be great.
!!! Smoke me a kipper boys ill be back for breakfast !!!
1984 TRX 200 Bone Stock
1981 ATC 185s Bone Stock
TRX200R is offline   Reply With Quote
Old 07-20-2011, 11:53 AM   #2 (permalink)
Liked: 52 times
Have you ever adjusted the clutch?
Old 07-20-2011, 02:43 PM   #3 (permalink)
Yeah, sounds like one of the clutches is slipping. Probably the change clutch. Time to replace the clutch discs.
Old 07-20-2011, 04:50 PM   #4 (permalink)
TRX200R's Avatar
Member #8936
no i have never ajusted it and should i replace the fiber ones and the steel ones or jst the fiber ones
Old 07-20-2011, 04:57 PM   #5 (permalink)
I usually just replace the fiber discs as long as the steel plates aren't warped or something. I use emery cloth, in a circular motion, to scuff up the plates just to de-glaze them a little. Don't forget to soak the new fiber discs in clean engine oil for about an hour before installing them.
Old 07-20-2011, 06:27 PM   #6 (permalink)
TRX200R's Avatar
Member #8936
ok i was also looking and there is the clutch shoes when should i replace those
Old 07-20-2011, 06:35 PM   #7 (permalink)
Yeah, that's the centrifugal clutch. It could be the clutch that's bad, but the way you described it, it sounds like the change clutch is the one that's slipping. The change clutch is usually the one that goes out first. You have to remove the centrifugal clutch to get to the change clutch, so while you have it off, you can measure the lining on the shoes and you can also measure the inside diameter of the clutch drum to see if they're withing spec.
Old 07-20-2011, 07:22 PM   #8 (permalink)
TRX200R's Avatar
Member #8936
ok thanks.
i had to rebuild my recoilstarter last night that was a blast so just one more thing to fix it was kinda sad that my 185 smokes the crud out of the 200
1984 honda atc 110 clutch adjustment
atc 110 clutch replacement
fourtrax 200 clutch
honda 185s clutch slipping
honda 200s clutch slipping
honda atc 110 change clutch plates
honda atc 200 slipping clutch
honda trx change clutch slips
how to adjust clutch on honda 200m
shop time replacing clutch disks in an atc110
why my honda atc is slipping
