06-08-2011, 09:06 AM
#1 (permalink)
Member #10908
oil in air box
Went for a ride last week, crossed a brook, bike quit, not to much water in brook Ichecked the aiir box, about 500 mil of oil in it, why and how did it get there?
06-08-2011, 11:23 AM
#2 (permalink)
Welcome to the forums...Free downloadable manuals in the Schematics/Manual help section on the Technical discussions board...What machine,How many hours,how deep was the water,how long since the oil,and filter were changed,and what weight oil?
06-08-2011, 12:26 PM
#3 (permalink)
Member #10908
oil in air box
2000 450es, 9800 kms, oil change 1500k ago ,water not over 16"
06-08-2011, 12:39 PM
#4 (permalink)
Have you done a compression check yet? It could be blowby caused by weak compression rings..Look at the little tiny foam filter in your airbox,see if it is oil saturated..If it is soaked,then it is prolly blow by,and if you run a compression check you may find that it is time for a top end job..If it isn't oil soaked,then maybe someone over oiled the air filter,and that is runoff,or dripped oil...Your machine may have quit due to water getting into the electrical connections shorting them..Check the fuses,and all wiring connections for water,and/or corrosion,clean them well,and apply dielectric grease everywhere...Have you pulled the dipstick to see if there's any water in the oil yet? Look for milky oil,or water droplets on the dipstick..
06-20-2011, 01:13 PM
#5 (permalink)
Member #10964
Same thing happened to me! The water wasn't high enough, but splashed in cuz I had holes drilled in airbox for filter and slip on! The water hit the filter and somehow rinsed off some of the red filter oil on mine into bottom of box! Mine sputtered but didn't stall! Cleaned air filter and reoiled it, and cleaned up oil in bottom, and it never happened again!
honda foreman oil in air box, honda foreman oil in airbox, honda get oil in air box, honda rubicon 500 oil in airbox, honda rubicon milky oil, honda rubicon oil in air box, honda rubicon oil in airbox, how to clean honda foreman 500 air, new honda foreman oil in airbox, oil in air filter box honda foreman, oil in the air filter honda 450 fourwheeler, oil in the air filter of 2008 honda foreman
