Rincon 680 oil drain plug. - Honda ATV Forum
Go Back   Honda ATV Forum > Honda Model Specific Discussions > Honda Rincon
Honda Rincon Discussions for the Honda Rincon 650 and Honda Rincon 680.
Old 06-02-2013, 04:30 PM   #1 (permalink)
Eastman's Avatar
Member #29640
View Eastman's Photo Gallery(0)
Just about to change the oil in my 2008 Rincon 680 for the first time.
Is the plug drain bolt a normal thread, i.e. turn left to loosen & right to tighten? Just want to be certain before starting. Also, what size socket or wrench do I need for the job? I was thinking of lifting the front of the ATV with the winch to help me get to the plug easier. Is that a good idea? I could lower it when the plug is loose?
Thanks,
Eastman.
Eastman is offline   Reply With Quote
Old 06-02-2013, 06:00 PM   #2 (permalink)
NC Rebel's Avatar
Member #1460
View NC Rebel's Photo Gallery(0)
Yes it has normal threads, CCW to loosen, CW to tighten. Be easy and do not over tighten, I understand it's easy to do. If you raise the front of the machine you will get more oil to drain that will not drain when it is level. Sorry, don't remember the wrench size.
Rincon 680
Recon 250
NC Rebel is offline   Reply With Quote
Old 06-02-2013, 07:04 PM   #3 (permalink)
Ballast's Avatar
Member #8124
View Ballast's Photo Gallery(0)
Liked: 31 times
^^^^ what's CCW and CW? 17mm if I remember right - torque wrench is a good investment to tighten stuff.
4 HONDAS 4 ME
85 TRX125.... sadly sold
Ballast is offline   Reply With Quote
Old 06-02-2013, 07:15 PM   #4 (permalink)
Tearitup's Avatar
Member #15481
View Tearitup's Photo Gallery(0)
ccw- counterclockwise cw- clockwise.
Tearitup is offline   Reply With Quote
Old 06-03-2013, 01:20 PM   #5 (permalink)
Melatv's Avatar
Member #11544
View Melatv's Photo Gallery(0)
Liked: 112 times
Same way you open a peanut butter bottle
25" Kenda K587 Bear Claws HTR
2500 Runva Winch
Melatv is offline   Reply With Quote
Old 06-03-2013, 01:27 PM   #6 (permalink)
Bryan's Avatar
Member #25021
View Bryan's Photo Gallery(0)
Liked: 121 times
Just a tad bit more expensive peanut butter lol
2014 Yamaha Grizzly 700 with Power Steering
5,000 Miles
Superwinch Terra 35 With Synthetic Rope
EHS Air Box lid
UNI Air Filter
1.5mm Shim Mod
Purple Spring
EHS Fuel Optimizer
Heat Demon Handle Bar Warmers
26x9 and 26x12 Maxxis BigHorn on 12" SS316 Matte Black
Canadian Yamaha Fender Flares
Plano 1510 Box
Join the Wisconsin Riders Group!
Click here for service manuals!
Bryan is offline   Reply With Quote
Old 06-03-2013, 01:28 PM   #7 (permalink)
Casey6404's Avatar
Member #28765
View Casey6404's Photo Gallery(0)
Please tell me this isn't the first time it's been changed since new in 2008..........
2010 Rancher 420 TM
Superwinch LT2000
26" Duro Power Grip Radials
ITP SS212 Wheels
Kolpin Overfenders
New Plastics (Old School 2007 Blue)
ODI Rogue Lock On Grips
2001 Recon
Casey6404 is offline   Reply With Quote
Old 06-03-2013, 01:52 PM   #8 (permalink)
HondaTinkerer's Avatar
Member #19090
View HondaTinkerer's Photo Gallery(0)
Liked: 12 times
Lefty loosy righty tighty. 17mm for oil bolt, do NOT overtighten (metal bolt into aluminum threads) or undertighten (if the washer slides down the bolt) when putting it back on or you will have another issue. Same with the oil filter housing bolts - to prevent overtightening those hold the socket wrench close to the center so you don't have as much leverage as near the end of the handle. They are easy to snap and very difficult to drill out and replace.
HondaTinkerer is offline   Reply With Quote
Old 06-03-2013, 03:01 PM   #9 (permalink)
Eastman's Avatar
Member #29640
rincon 680 oil drain plug.
Thank you all for your info & advice. I did the oil change today and it seemed to go well. I only got the Rincon a couple of months ago, and decided to change to synthetic oil. I have never done this before because this is my first ever ATV!! I wanted to do it myself, but not cock things up, so I asked you for advice. I did find it difficult to use a socket wrench for the drain bolt because I couldn't get the wrench on the socket once the socket was on the bolt head. There just wasn't enough room because of the skid plate, so I used a regular wrench, as I didn't want to remove the plate.
Anyway, I manged to do the job, and can't see any leaks!
I used Mobil1-4T racing, and it took around 3.5 quarts. I'll take it for a run when the rain stops, and check it out.
Thanks again.
eastman
PS. Honda Tinkerer, What do you mean by the washer sliding down the bolt??
Old 06-03-2013, 03:10 PM   #10 (permalink)
Ballast's Avatar
Member #8124
Liked: 31 times
Know what you mean about the skid plate - last year I removed the plate - BIG MISTAKE - it fit much better when new and not all bashed up. This year I removed the drain plug and let the oil find its own way to the floor
Thanks for the CCW / CW clarification
4 HONDAS 4 ME
2007 honda recon 680
drain plug on honda rincon 680
honda rincon 650 oil in oil filter box
honda rincon 680 oil and filter change
honda rincon 680 oil change
honda rincon 680 oil drain plug
honda rincon drain plug
how to change oil in honda rincon 680
how to change oil on a honda rincon 680
oil plug o7 honda rincon
rincon drain plug size
where is the oil drain plug on a honda rincon
