2003 honda rancher es electric shift not working - Honda ATV Forum
Old 11-17-2010, 09:51 PM   #1 (permalink)
2010ron37's Avatar
Member #6787
View 2010ron37's Photo Gallery(0)
just bought a 2003 rancher 2wd just had a new crank shaft and top end rebuild it will shift up on the electric shift but not down and sometimes will not shift at all any help would be great thanks
2010ron37 is offline   Reply With Quote
Old 11-17-2010, 09:58 PM   #2 (permalink)
Welcome to the forums. Is the battery good and fully charged? A weak or bad battery can cause shifting problems.
When you turn the key on, does the gear position indicator flash? If so, count the flashes, it's indicating a trouble code.
Old 11-17-2010, 11:15 PM   #3 (permalink)
2010ron37's Avatar
Member #6787
the display unit does not light up but there is a light that flashes twice i believe its the oil light
Old 11-17-2010, 11:21 PM   #4 (permalink)
2010ron37's Avatar
Member #6787
i just installed a new battery and its fully charged he said the shifting was working fine until he did the rebuild his son drove it once in the yard right after the rebuild and thats when the problem happened whats weird is it would shift up when iput the new battery in then it stopped when i manualy shifted back to neautral
Old 11-18-2010, 05:41 PM   #5 (permalink)
If the display doesn't work, the only thing I know to do is to check each individual component in the electric shift system. The angle sensor is a common problem and might be a good place to start. You can download the service manual that will show you how to test the components at the link below.
http://www3.telus.net/leneng/pdf/Hon...air_Manual.pdf
Old 11-19-2010, 12:49 AM   #6 (permalink)
2010ron37's Avatar
Member #6787
thank youvery much i ordered a new angle sensor and a display unit today the display unit looked like it had been under water so ill start there thank you fr your help
2003 honda rancher 350 es shifting problems
2003 honda rancher 350 will not shift
2003 honda rancher electric shift problems
2003 honda rancher electronic shifter
2003 honda rancher es not shifting
2003 honda rancher es shift problems
2003 honda rancher350 electric shift problems
2003 rancher electronic shift alternate
electronic shift on honda rancher not working
honda rancher electric shift not working
honda rancher electronic shift program not working
