Oil Leak - Honda ATV Forum
Old 10-19-2010, 06:27 PM   #1 (permalink)
Mudmannolan's Avatar
Member #812
View Mudmannolan's Photo Gallery(0)
Oil Leak
Picture is of an oil leak i recently discovered. It is leaking very heavily, i cleaned it all off and then went for a 1 mile ride and it looked like this. The oil fill cap is just outside of the frame on the right.
I know it could be many things but I'm hoping that someone will recognize an apparent problem. I felt and looked above this spot for broken or punctured lines and found nothing, so I assume it must me coming from the seal that can be seen in the picture. Would that be just a broken seal or maybe a blown head gasket? See what you think... It's my '05 Rancher AT 400.
2003 Bombardier Quest 650
2005 Honda Rancher 400, 25" Kenda Bearclaws, Mad Dog gun rack, Cup Holder, Custom Audiopipe, .50 cal Ammo Can
Coming soon: Improved metal floorboards
I'm offended by political jokes. Too often they get elected.
Mudmannolan is offline   Reply With Quote
Old 10-19-2010, 06:30 PM   #2 (permalink)
Member #812
Sorry mods, didn't mean to post three of these. If you delete two of them please keep this one up.
Old 10-19-2010, 06:33 PM   #3 (permalink)
Just looks like the base gasket under the cylinder is leaking, to me.
Old 10-19-2010, 06:50 PM   #4 (permalink)
Member #812
Which means what? Just an inexpensive gasket to replace? How in depth would replacing that be?
Old 10-19-2010, 06:52 PM   #5 (permalink)
You have to pull the valve cover, head, and cylinder off to replace it.
Old 10-19-2010, 06:54 PM   #6 (permalink)
Member #812
Thanks, ill try to look into that.
Old 10-19-2010, 07:00 PM   #7 (permalink)
The oil that gets pumped to the top of the engine goes up through that front bolt hole, around the bolt. That's probably why it's leaking so fast.
Old 10-19-2010, 08:17 PM   #8 (permalink)
Member #812
Alright thanks. I should be able to tear into it Saturday.
Old 10-19-2010, 08:32 PM   #9 (permalink)
Liked: 1508 times
look like a leaking base gasket..replace it..easy fix.
Old 10-27-2010, 02:10 PM   #10 (permalink)
duaneduanet's Avatar
Member #3168
View duaneduanet's Photo Gallery(0)
Just be careful of the oil rings taking them out and back in. Also I had to adjust the valves when I took mine apart. You might or might not have to do that. You will know when you crank it back up
2008 Honda Foreman 500 ES PS 4X4
duaneduanet is offline   Reply With Quote
2005 350 rancher oil leak
2005 honda rancher at leaking oil
change head gasket on 2004 honda foreman
hiw to fix a oil leak on a honda rancher 400 valve cover
honda foreman 450 es leaking from cylinder base
honda foreman leaking oil
honda foreman oil leak
honda forman oil leak
honda rancher leaking oilbetween the head and block
honda rancher oil leak
top of block leaking oil 2004 honda foreman atv
why would oil be on cylinder head honda foreman
