2000 honda rancher es 4x4[ stuck in reverse - Honda ATV Forum
Old 06-01-2010, 08:17 PM   #1 (permalink)
hosanger2099's Avatar
Member #3386
View hosanger2099's Photo Gallery(0)
Unhappy 2000 honda rancher es 4x4[ stuck in reverse
I just got this honda ,it only has 1221 miles on it,and it is stuck in reverse,tried to shift it manually, it wont change like that either,no blinking code, soon as you turn on the key displays R, and it wont let it even turn over, while its in gear,,any body PLease help
hosanger2099 is offline   Reply With Quote
Old 06-01-2010, 08:27 PM   #2 (permalink)
69quadracer's Avatar
Member #805
View 69quadracer's Photo Gallery(0)
Liked: 10 times
I don't have an answer for you about it sticking in reverse, but someone here will soon. Welcome to the forums!
69quadracer is offline   Reply With Quote
Old 06-01-2010, 08:35 PM   #3 (permalink)
Welcome to the forums. The '00-'02 models don't have the ability to store trouble codes. The manual says if you can't change gears with the manual shifter, then you have a faulty transmission or gearshift linkage.
Old 06-01-2010, 08:37 PM   #4 (permalink)
BTW, here's a link to a free 350 Rancher repair manual, in case you don't have one.
http://www3.telus.net/leneng/pdf/Hon...air_Manual.pdf
Old 06-04-2010, 03:09 PM   #5 (permalink)
Monkey11's Avatar
Member #3420
View Monkey11's Photo Gallery(0)
Any advice on a 2002 Honda ES FOREMAN Stuck in reverse.
Monkey11 is offline   Reply With Quote
Old 06-04-2010, 08:05 PM   #6 (permalink)
If the gear position indicator on the display is blinking, then read out the trouble codes.
2000 honda foreman 400 stuck in reverse
2000 honda foreman stuck in reverse
2000 honda rancher 350 es stuck in reverse
2000 honda rancher es stuck in reverse
2000 honda rancher stuck in reverse
4 wheeler stuck in reverse
four wheeler stuck in reverse
honda 4 wheeler stuck in reverse
honda atv stuck in reverse
my 4 wheeler is stuck in reverse
