420 Gear Reduction - Honda ATV Forum
post #1 of 10 (permalink) Old 01-08-2014, 08:50 AM Thread Starter
cccharged's Avatar
420 Gear Reduction
After searching on here for about an hour I give up. Is there any type of write up on the process it takes to a gear reduction? I found quite a bit on the AT's but not much the SRA models like mine. I have 28" Mega Mayhems on mine and in first gear it doesn't do bad in normal mud but anything thick or deep it really just hates it. What % to do and WHERE to get it or WHO to buy it from?? Thanks.
2012 ES SRA 420 Rancher
-28" Mega Mayhem's
-14" HD2se's
cccharged is offline
post #2 of 10 (permalink) Old 01-08-2014, 01:14 PM
brianamedley's Avatar
Liked: 12 times
Any gear reduction bigger than the SRA reduction for an AT should work in yours it just won't be as much of a reduction from stock. I think HL sells a reduction for it.
2012 Rancher AT-MSA Nukes w/ 28 Zillas, 2" Lift, 3k winch, Custom Stereo, Ammo Cans for storage, Cold Shrink Cable sleeve for grips
2007 400ex-SS112 sport w/ GNCC holeshots, Trinity full exhaust, Pro Armor rear skid, nerfs, and front bumper
brianamedley is offline
post #3 of 10 (permalink) Old 01-08-2014, 01:42 PM
Banned
jcooperpcola's Avatar
Liked: 51 times
I would check with GotMuddy on the Highlifter Forum. He makes gear reductions for just about everything.
jcooperpcola is offline
post #4 of 10 (permalink) Old 01-08-2014, 07:11 PM Thread Starter
cccharged's Avatar
I was wanting to know what it all involved. Not super detailed but just a little deeper information.
-28" Mega Mayhem's
-14" HD2se's
post #5 of 10 (permalink) Old 01-08-2014, 07:33 PM
Liked: 12 times
You pull the rear case off, change the primary and secondary drive gears, replace the rear case, then shave the speed sensor down so it drops farther into the case so it will shift right. The most basic description I can give.
post #6 of 10 (permalink) Old 01-10-2014, 07:01 PM Thread Starter
cccharged's Avatar
Thanks! I think this would be better than buying exhuast,filter and programmer.
-28" Mega Mayhem's
-14" HD2se's
post #7 of 10 (permalink) Old 01-12-2014, 01:33 PM
crazy_j225's Avatar
Honda 420 secondary gear reduction install info
2011 rancher at
2" high lifter lift
High lifter springs
K&N and pre filter
Hmf penland pro
Pcv
28 in s/w zillas
Extreme gear reduction (32%)
Epi comp clutch kit
Full 2in snorkel
Rad rack
crazy_j225 is offline
post #8 of 10 (permalink) Old 01-12-2014, 06:55 PM Thread Starter
cccharged's Avatar
That explains it very well! Thanks for sharing that!
-28" Mega Mayhem's
-14" HD2se's
post #9 of 10 (permalink) Old 01-21-2014, 09:44 PM
Smokenjoe's Avatar
Hey what's up guys! I just joined this forum and also just purchased a 2013 rancher 420 4x4. I'm excited about both. I'm wanting to learn the most beneficial accessories to help open it up and gain a little power. Also I want to make it as bright as possible at night time. I've seen a few exhausts out there. Didn't know if I needed to tune or anytning else after installing one. Any helpful tips or suggestions would be much appreciated.
Smokenjoe is offline
post #10 of 10 (permalink) Old 01-22-2014, 08:11 PM
crazy_j225's Avatar
If ur just doining a pipe u shouldmt need a programmer but every bike is different if ur just wanting a little more power and don't want knock ur speed down I would go with the 14.5 % gr but if ur wanting all out mud then the 35% as far as lights the only aftermarket hids r made by eagel eye
2011 rancher at
2" high lifter lift
High lifter springs
K&N and pre filter
Hmf penland pro
Pcv
28 in s/w zillas
Epi comp clutch kit
Full 2in snorkel
Rad rack
