2006 350 trx carburetor - Honda ATV Forum
Old 07-10-2013, 03:59 PM   #1 (permalink)
ronalines's Avatar
Member #32172
View ronalines's Photo Gallery(0)
2006 Rancher 350 Strange Carb. Problem
My Rancher is doing something strange. If I park it on a small incline at my garage, it won't start the next day. I have to back it out manually and get it on a down hill incline and it will start right up. It's full of gas and runs perfect after it starts. I'm sure it is a carburetor problem as it did this about a year ago. After a company rebuilt the carb., the problem went away. Now it is back again. I use sea foam in every 5 gallon gas can I fill up, ounce to the gallon. I wonder if it wintering over in the Virginia cold has anything to do with it...Strange problem.
Thanks Ron Lines
ronalines is offline   Reply With Quote
Old 07-10-2013, 06:00 PM   #2 (permalink)
kentco's Avatar
Member #16201
Liked: 1455 times
Could be a bad float valve in your carbureator - which allows the bowl to overfill and flood.
Old 07-11-2013, 01:53 AM   #3 (permalink)
RancherGuyy's Avatar
Member #31440
View RancherGuyy's Photo Gallery(0)
Liked: 10 times
My 06' 350 float gets stuck after I store it for winter and sometimes after sitting. Just take a little piece of wood put it on the carb and tap it with a hammer to loosen it up a little, always does the trick if it's a sticky float.
2016 Yamaha Grizzly 700 EPS Steel Blue
ITP 12" SS212's
Maxxis Bighorns
26x9-12 and 26x12-12
Previous Machines
-2014 Honda Rancher 420 ES
-2006 Honda Rancher 350 ES
-2001 Honda Rancher 350 Foot Shift
RancherGuyy is offline   Reply With Quote
Old 07-11-2013, 08:32 PM   #4 (permalink)
ronalines's Avatar
Member #32172
Thank you brother..good advice.
Old 07-11-2013, 08:34 PM   #5 (permalink)
ronalines's Avatar
Member #32172
Interesting. I'll try tapping on the carb. I'm trying to understand why pointing it downhill causes it to start. Is it aluminum oxide that makes the float begin to stick or what actually causes it? Wonder if I should pull it out and clean it real good.
Thanks Again
Old 07-11-2013, 10:07 PM   #6 (permalink)
Liked: 1528 times
Thanks Again
do yourself a favor...remove the gas tank..drain it..then pull the petcock from the bottom of the tank..check the pick up screen ?..make sure it's clean ?..make sure you don't have any trash inside the tank ??. thennnnnn..install an inline fuel filter between the petcock and carb !!!..if any trash gets by the main screen in the petcock...the inline filter will catch it..before it gets to your float needle in the carb..which just happends to be one of your problems !.
Old 07-11-2013, 10:46 PM   #7 (permalink)
jdp
jdp's Avatar
Member #16593
View jdp's Photo Gallery(0)
Liked: 74 times
I been meaning to get me a fuel filter but ain't done it yet. Look in your air box and see if any is leaking in it, smell it to see also.
1993 Honda 300
Seafoam "In every tank"
Superwinch Terra 35/synthetic rope, KFI winch Mount.
AMS Swampfox front 23x8x11, GBC dirt devils 25x12x9 rear.
jdp is offline   Reply With Quote
Old 07-12-2013, 03:06 PM   #8 (permalink)
ronalines's Avatar
Member #32172
That is great advice. Didn't know there was an screen in petcock. Wish Honda would have just put a fuel filter inline to begin with...I will drain the tank and inspect the screen. Thank you.
Old 07-12-2013, 03:07 PM   #9 (permalink)
ronalines's Avatar
Member #32172
Air box good and tight...not a sniff of vapor anywhere. Thanks for the tip!
Old 07-12-2013, 06:44 PM   #10 (permalink)
jdp
jdp's Avatar
Member #16593
Liked: 74 times
sure thing friend
1993 Honda 300
2006 honda 350 rancher carb problems
2006 honda 350 rancher carburetor
2006 honda atv 350 trx fm6 carbortor
2006 honda rancher 350 es carburetors
2006 honda trx 350 tm carburetor float
does 2006 honda 500 battery have anything to do with carburetor
honda trx 350 tm fuel filter
how to install carb on 2006 honda rancher 350
how to install carburator kit in 2006 honda rancher
installing caburetor on 2006 350 rancher
keikhin 350 trx carb
what is the size carburetor on 2006 honda trx 350
