Rancher tries to die when exhaust is under water. - Honda ATV Forum
Old 04-08-2013, 09:59 PM   #1 (permalink)
cccharged's Avatar
Member #16208
View cccharged's Photo Gallery(0)
When I get in anything that puts my exhaust underwater my rancher seems like it just looses power? No matter how much throttle I give it just stops making power and tries to die..once I get it in a bit shallower water it does fine. It is stock except for wheels and tires. Something getting wet? Some type of back pressure issues when the exhaust goes under water?
2012 ES SRA 420 Rancher
-28" Mega Mayhem's
-14" HD2se's
cccharged is offline   Reply With Quote
Old 04-08-2013, 10:44 PM   #2 (permalink)
Trips's Avatar
Member #17730
View Trips's Photo Gallery(0)
I doubt its the exhaust problem
Are all the wire connections die electric greased as well as the spark plug boot?
as well all the vent line are they run up?
1990 Honda Fourtrax 300 Dubbed "The Blue Bull"
Trips is offline   Reply With Quote
Old 04-09-2013, 08:50 AM   #3 (permalink)
cccharged's Avatar
Member #16208
Are all the vent lines not ran up to the factory intake tube?
-28" Mega Mayhem's
-14" HD2se's
Old 04-09-2013, 01:32 PM   #4 (permalink)
Trips's Avatar
Member #17730
Re: Rancher tries to die when exhaust is under water.
The check valve in the drain tube of the carb might be messing up. Could also be electrical that's causing it
Old 04-09-2013, 08:38 PM   #5 (permalink)
fordtech90's Avatar
Member #5902
View fordtech90's Photo Gallery(0)
Raise the vent lines and put dielectric grease in the plug boot. Also make sure the air box is not filling up with water, if so you need a snorkel.
BACK IN ACTION
2010 Rancher 4x4 es.......Front Brush Guards
12" SS 312....................Gorilla Radiator Relocate Kit
28" Outlaws Skinnies........K&N Air Filter
Power Commander V........Black and Red Pro Grips
Fully Snorkled................NGK Iridium Spark Plug
2" Moose lift..................Big Gun Evo Exhaust
2" Spring Spacers...........2600 rpm stall Clutch Kit
3" wheel spacers............Venom 3500lb winch
HID's............................JE high compression piston
bored .020
fordtech90 is offline   Reply With Quote
Old 04-09-2013, 08:55 PM   #6 (permalink)
Member #417
Liked: 286 times
or buy a boat they go really fast on the water. . . . lol
Old 04-10-2013, 09:18 AM   #7 (permalink)
cccharged's Avatar
Member #16208
Vent tubes have been ran.The plug boot has been greased and if there would have been water in my airbox then that pretty much would have told me what my problems were and I would have said the "the rancher tries to die when the airbox is full of water" instead of "the rancher tries to die when exhaust is under water."...and of course I would get the moron award for starting a thread on why my fourwheeler dies when the airbox is full of water lol. Anyways, I have talked to several guys with stock exhaust rancher's that say with their stock exhaust goes under their rancher also starts just loosing power and tries to die. If you get lucky and get the exhaust back out before it does die it does fine..I believe it is somehow related to back-pressure. Guy's say that when they changed to aftermarket the problem stopped or they snorkeled their exhaust.
-28" Mega Mayhem's
-14" HD2se's
Old 04-10-2013, 09:21 AM   #8 (permalink)
Banned
jcooperpcola's Avatar
Member #12230
View jcooperpcola's Photo Gallery(0)
Liked: 51 times
Try plugging the carb overflow
jcooperpcola is offline   Reply With Quote
Old 04-10-2013, 12:01 PM   #9 (permalink)
meedom's Avatar
Member #19610
View meedom's Photo Gallery(0)
Shouldn't be a carb overflow, it's fuel injected.
2012 TRX420FA
Reverse Mod
"25" Original Bighorns on Rincon aluminum rims
2008 TRX420TE...wifes, all stock
2008 Polaris Sportsman 400 HO...sold for TRX420FA!!!
meedom is offline   Reply With Quote
Old 04-10-2013, 09:47 PM   #10 (permalink)
Banned
Member #12230
Liked: 51 times
I cant see his sig on Forum Runner so I have no clue which Rancher he has..
2008 honda rancher fuel injected fuel vent line
2015 420 rancher dies in water
atv muffler went under water
atv rancher 350 keeps stalling under deep water
backpressure in a honda rancher 420
can your atv exhaust go under water with a air box snorkle
honda rancher 350 cuts off in water
honda rancher 350 dies in shallow water
how to stop a 350 rancher from dying under water
my 350 rancher get dieing when i get on the blacktop
what will happen if i remove the bolt on bottom of muffler on rancher 420
will a snorkel on a honda rancher 420 hurt anything with a stock exaust
