fuel leak - Honda ATV Forum
Old 09-16-2012, 03:06 PM   #1 (permalink)
jeeper88's Avatar
Member #23264
View jeeper88's Photo Gallery(0)
fuel leak
I have a 2005 Honda Rancher 350 2x4, It has a fuel leak coming out of the carb, at the bottom of the carb is a nipple with no hose to it and whenever the fuel is on the fuel runs right out of that nipple. I could not find a loose hose laying around so I am wondering if it is suppose to have a cap on it or the hose is missing, if someone could tell me if there is a hose where it would run to or anything on it. Thanks
jeeper88 is offline   Reply With Quote
Old 09-17-2012, 08:28 PM   #2 (permalink)
mvandillon's Avatar
Member #23313
View mvandillon's Photo Gallery(0)
Try and plug that hole and if your 4 wheeler runs with the hole plugged up there was never a hose that was supposed to be there
mvandillon is offline   Reply With Quote
Old 09-17-2012, 08:31 PM   #3 (permalink)
Trips's Avatar
Member #17730
View Trips's Photo Gallery(0)
That is your barb drain and yes there should have been a hose there running past the engine to the ground. They usually have a one way check valve on them.
If it is leaking out of there you have an issue with your needle and seat. Its sticking and your bowl on the carb is filling over full. That is why its leaking. You are going to have to pull the carb and clean it and possibly replace the needle and seat.
1990 Honda Fourtrax 300 Dubbed "The Blue Bull"
Trips is offline   Reply With Quote
Old 09-17-2012, 08:32 PM   #4 (permalink)
Trips's Avatar
Member #17730
That is your carb drain and yes there should have been a hose there running past the engine to the ground. They usually have a one way check valve on them.
Old 09-17-2012, 09:23 PM   #5 (permalink)
teddybaham's Avatar
Member #22295
View teddybaham's Photo Gallery(0)
exactly!!!
teddybaham is offline   Reply With Quote
Old 09-17-2012, 10:36 PM   #6 (permalink)
jkhuntin's Avatar
Member #4493
Liked: 16 times
Welcome from the Volunteer state. What Trips said.
2004 Rincon
2" lift
27" mudlites, ITP SS212's
Mud bike
2013 Rancher 420 AT.
jkhuntin is online now   Reply With Quote
Old 09-17-2012, 11:02 PM   #7 (permalink)
sabre54's Avatar
Member #17833
View sabre54's Photo Gallery(0)
Yup to Trips. Usually if you just clean the cone shaped rubber on the top of the needle valve and blow any dirt or sand out of the seat that will solve the problem.
1996 Foreman 400 FW, 2007 420FM Rancher,2008 420FM Rancher,2009 Foreman 500 FPM
sabre54 is offline   Reply With Quote
Old 09-18-2012, 09:32 PM   #8 (permalink)
jeeper88's Avatar
Member #23264
Alright, thanks guys, when I get home next I am going to do that
Old 09-18-2012, 09:46 PM   #9 (permalink)
Liked: 53 times
If it is the drain nipple,tightening the screw in the side of the bowl should stop it,if it doesn't,then the oring is shot on the drain screw,and needs replacing along with a length of fuel hose small enough to be forced onto that nipple,and ran down below the bottom of the engine to the rear(look around n see if the old ones back there hanging around still)...If the carbs needle is sticking then usually the drip is pretty fast..try tapping on the carb body with a screwdriver a few times to see if you can shock the float loose,and stop the drip after you check the drain screw for tightness..A small zip tie,or piece of fine wire applied tightly around the hose will suffice to hold it in place...
Old 09-20-2012, 05:49 PM   #10 (permalink)
jeeper88's Avatar
Member #23264
Thank ya, I got a carb rebuild kit from rockymountain atv and me and my buddy are going to rebuild the carb tomorrow evening and do a once over on it. The thing is 7 years old and has sat for the last 5 at least. When I start this I will look at all of the parts to make sure it is all good.
2005 honda rancher 350 leaking fuel from barb on bottom of carb bowl
2005 honda rancher 350 leaking gas
2006 foreman 500 fuel line from carb bowl
2006 honda rancher 350 fuel leak
gas hose connection honda foreman 500
gas leaks out the carb when i seitch to reserve on my honda atv
honda atv fuel leak
honda rancher 350 carburetor leaking gas
honda rancher carburetor leaking gas
honda rancher gas leak
old four wheelers leaking fuel
why does my honda 2002 four wheeler leak gas
