03-01-2010, 09:14 PM
#1 (permalink)
Member #2201
400 At rancher needs help
I just bought a 2004 400 Rancher AT, I just had the motor rebuilt, new clutchs and highlifter clutch kit put in. The other day i was ridin, for about 1.5 hrs in what off and on, and it started sliping and finally quit pullin. We left it there for about two hrs and it rode just fine. does anyone know what caused that? could it be heat related? and also what does the motor assy control do? Its on the front of the crank case around the tranny.
03-01-2010, 09:17 PM
#2 (permalink)
Member #417
What kind of oil did you put in it?
Welcome to the forums.
MOOSE
1991 TRX 250X
12:1 wiesco piston @ 60 over
stage 1 cam,
Vesra connecting rod
High performance coil
jet kit, 400EX carb, K&N filter,
FMF power Core 4 full exhaust,Tusk nerfbars.
Coming soon Ported and polished headECT. ECT.
03-01-2010, 09:25 PM
#3 (permalink)
Member #2201
thanks, valvoline 10-40 ATV oil. what oil do i need to use?
03-01-2010, 09:36 PM
#4 (permalink)
Member #417
That should be fine if it was designed for wet clutches, I use GN4 hona oil myself tht way i know I have the right oil. it sounds like you may have lost your clutches again? It runs fine but won't pull right? Did you get any flash codes?
MOOSE
1991 TRX 250X
stage 1 cam,
03-01-2010, 10:43 PM
#5 (permalink)
Member #2201
how do i get the codes to flash? and after it sit for about 2 hrs. it went back to pullin and goin right again, just when you stop you can something like an actuater in a 4x4 truck kickin. this is the first auto wheeler i've had so i dont know much about them yet.
03-01-2010, 11:27 PM
#6 (permalink)
the codes they are speaking of..flash on your display when you turn the key on..but..from what your telling us..it does sound like your clutch is going in and out..probally from over heating..i'd say get new clutch disk...maybe who ever put them in..put them in wrong ??..that's what it sounds like to me...seeing how you let it set for two hours..then went back to it..by that time..the clutch had time to cool down. so..look at a clutch problem from the sound of it.
03-02-2010, 05:32 PM
#7 (permalink)
Member #2201
Does anybody know what the control motor does, could that be causin a problem?
03-02-2010, 07:35 PM
#8 (permalink)
Everyone keep in mind that this is an automatic transmission. I don't know much about the Honda automatic transmission since I always stick with the foot shift, but I found the following information on the internet. This is from 4X4 Review Offroad Magazine.
"Honda provides the Electronic Shift Program (ESP). Since the Rancher AT has a CVT, there are no actual gears, but the transmission does have five preset ratios which are controlled by thumb switches next to the left handgrip. This allows you to lock the transmission in a low "gear" for navigating steep hills or pulling heavy loads. ESP mode produces the smoothest shifts I have ever felt in any vehicle. When you shift with the throttle wide open, the only sign that you have changed gears is the audible change in engine RPM and the gear position indicator on the gauge cluster."
"One of the biggest advantages of this transmission is that it doesn't use traditional drive belts. Most ATVs with automatic transmissions employ rubber belts as their primary drive mechanism, and if they get wet, your ride is over until they dry out. The Hondamatic is completely sealed and instead of belts, it uses a set of pump and motor pistons with a motor side swash plate to continuously change motor side hydraulic capacity. The device is maintenance free, but the drawback is that if you break it, plan on spending about $1000 to replace it, as there are no dealer serviceable parts inside."
Everyone's entitled to their own opinion, even though mine is right and yours is wrong.
03-02-2010, 07:58 PM
#9 (permalink)
yikessssssss !..lol
03-03-2010, 09:10 AM
#10 (permalink)
Member #2201
Sweet! but before i spend 1000 dollars. im goin to try replacing the control motor($100) on the front which controls the angle of the one of plates that control the fluid, b/c some other ppl have had the same problem with there 400 AT Rancher and said that fixed it.
» Site Navigation |
» Honda Forums
