Rancher? - Honda ATV Forum
Old 08-14-2012, 09:08 PM   #1 (permalink)
all4honda's Avatar
Member #11937
View all4honda's Photo Gallery(0)
Rancher?
I've been wanting a utility for a long time(never had one). All the different models are confusing me a bit not knowing anything about them.
What rancher offers select 2/4wd, irs, power steering, all wheel desent braking. Looking to stay in the midsize quad 350/420
all4honda is offline   Reply With Quote
Old 08-14-2012, 09:16 PM   #2 (permalink)
bobs330's Avatar
Member #8144
The TRX420FPA is your match. It has power steering, IRS, and and auto/manual tranny. Also, on the 420s, they are 2wd/4wd selctable with a knob on the left side of the tank. Here is the link to Honda's website so you can see the available options on this machine. Its commonly referred to as the Fourtrax/Rancher 420 AT. Hope this helps!
2013 FourTrax Rancher AT Innovations - Honda Powersports
2011 Rancher 420 FPM
AMS Swamp fox tires
Stearns rear rack bag
Superwinch Terra 25
Moose rear bumper
Old 08-14-2012, 10:32 PM   #3 (permalink)
Yep, if you want power steering and selectable 2wd/4wd, then you're limited to the 420 Rancher. The 350 Rancher has neither. And not all of the 420s have power steering.....you can get them with or without the power steering.
Old 08-14-2012, 10:46 PM   #4 (permalink)
dcfox's Avatar
Member #17852
View dcfox's Photo Gallery(0)
I have a 420FPA and love it.
You won't be disappointed.
--David
2009 Honda TRX420FPA (mine)
2006 Honda TRX350TM (wifes)
2006 Honda TRX350TE (daughters)
2001 Honda TRX350TE (sons)
2007 Yamaha Rhino 450 (also mine)
ADD ME ON FACEBOOK
"If It Weren't For Physics And Law Enforcement I'd Be Unstoppable!"
dcfox is offline   Reply With Quote
Old 08-14-2012, 10:52 PM   #5 (permalink)
falconblack's Avatar
Member #10220
View falconblack's Photo Gallery(0)
Looks like a nice machine alright
falconblack is offline   Reply With Quote
Old 08-15-2012, 04:01 PM   #6 (permalink)
all4honda's Avatar
Member #11937
Thanks Bobs, that was very helpful. The rancher comes a lot of different ways. The 420fpa is a really,really,really nice quad, looks like I'll be wanting one for a while longer. lol
dcfox hows that auto tranny? They are not belt drive? Like I said I don't know anything about these
Old 08-15-2012, 05:18 PM   #7 (permalink)
dcfox's Avatar
Member #17852
not a belt drive.
it's a 5 speed auto trans.
The 420at isnt geared as low as the sra models...and won't turn larger tires as well...but a sra gear swap will fix that(mine will be getting this done this winter)
--David
ADD ME ON FACEBOOK
Old 08-15-2012, 07:14 PM   #8 (permalink)
bobs330's Avatar
Member #8144
No honda quads are belt drive. They are all either hydraulic, or geared. The 420 has alot or power, and is a very good trail quad. The 4wd is easy to engage/disengage. Theyre a really good choice.
AMS Swamp fox tires
Superwinch Terra 25
Moose rear bumper
Old 08-15-2012, 09:14 PM   #9 (permalink)
kentco's Avatar
Member #16201
Liked: 1455 times
All4: To get 2/4WD, Auto/Manual(ES) Shift, Independent Rear Suspension, Increased ground clearance, and power steering, the Rancher 420AT is the machine. It's probably one of the very best all-around, most versitile machines made.
Old 08-16-2012, 04:56 PM   #10 (permalink)
nanuk's Avatar
Member #3579
View nanuk's Photo Gallery(0)
I would recommend the rubicon trail edition and if memory serves the 2012/13 models now have power steering. It's a hydrostatic drive with automatic shifting but it does allow you to shift manually. I would recommend the solid rear axle version of the rancher if you are going to work a-lot.
__________________________________________
2009 Honda Rancher 420 FPE.
H-L Detroit FDL.
Dual battery.
Pull start.
26" Kenda Executioner tires.
Externally mounted Runva 2500lbs winch.
J-wheelz.
So long as i am far away from humanity i am content.
nanuk is offline   Reply With Quote
2012 rancher belt driven?
disadvantages for 2012 suzuki ozark 250
does the honda 420 stay in 4 wheel drive
honda 420 rancher rear driveshaft longer
honda rancher 420 vs grizzly 450
honda rancher at 400 4wd wont engage
how to engage 4 wheel drive on honda 420 rancher
how to engage and disengage four wheel drive on a 2001 honda rancher
what year did honda ranchers have select shift
what year did the rancher atv have selectable 4wd
what year honda rancher had the 4wd shifter on the left side
what year rancher has selectable 4wd
